Question about Star Micronics TSP650 Thermal Printer
Tsp650 printer shows offline and won't print - Star Micronics TSP650 Thermal Printer
Where is ink cartridge located?
This tis a Direct Line Thermal printer and does not use a cartridge. You use special paper that is chemically coated to react to print. http://www.newegg.com/Product/Product.aspx?Item=N82E16828154100
Apr 21, 2016 | Star Micronics TSP650 Series - TSP650...
Brother HL-2270DW printer shows offline and won't print
I had this problem today with my wireless Brother MFC-990CW using Windows 7, and when I went to see what s printing, then printer, it wasn t showing that I had checked the use printer off-line
So, on my pc I went to the start button then chose:
- Computer
- Network
- Double click your printer
- New print drivers will start to install
- Right click the icon that is a copy made of your printer setup
- Set this as your default printer
I was then able to print and my printer didn t show as being off-line anymore. This is a lot easier than having to uninstall and install the printer again using the disc.
Source(s):
https://answers.yahoo.com/question/index?qid=20140422184955AA0dJ7F
Jun 27, 2012 | Brother HL-2040 Laser Printer
Printer is offline
Did you check the connection of both the USB and the power? Those are the two most common responses for that error.
More information might be needed if problem persists.
Nov 27, 2011 | Office Equipment & Supplies
Photosmardt c510 won t print messaging sayin it is offline
Assuming you are running a version of Microsoft Windows. Try going to Start -> Control Panel -> Printers Right click on your printer and make sure that "Use Printer Offline" is NOT checked.
Mar 23, 2011 | HP Computers & Internet
My printer says its offline how do I reconnect? I've already done a complete power off and it's still offline.
hi
just folow the step
Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Jul 07, 2010 | HP Deskjet 6940 InkJet Printer
Brother mfc490cw printer show offline and erro
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Aug 06, 2009 | Office Equipment & Supplies
Printer will not print computer shows it as offline
Hi!
You just need to right click on the default printer (which you are using for printing) and then click on 'use printer online' and you will be able to print.
Thanks for using FixYa and do rate the solution as FixYa if found helpful and revert back for any assistance.
Thanks
Rylee
Apr 07, 2009 | HP Office Equipment & Supplies
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Star Micronics TSP650 Thermal Printer Logo
24 people viewed this question
Top Star Micronics Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
