Question about Fujifilm Finepix S2980
Lens become stuck
The problem is that the lens has become stuck in the barrel
    Top Expert:
  • Fuji Master
  • 6,702 Answers
Do you know what caused the lens to get stuck? Did someone drop it, or was the camera a long time not used?
Most of the time this is a mechanical problem. At least is you still can switch the camera on and get into the menus and when you still can view pictures taken.
In rare occasions, the blockage can be released with a little shock to the camera. Never use force on a camera, or tick something against a camera. you could slap your hand, holding the camera, but not hard. But when the blockage is caused by a broken gear, noting will help. The camera should go to a repair store.
Before you do, be sure the battery is fully charged. An old battery, could cause trouble too. More often than you can think of.
Posted on Nov 24, 2013
Lens will not retract not batteries
Hello
You especially might consider this if the lens barrel appears obviously damaged, bent, or crooked such as from a fall. Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
hope it helps, if not take camera to the technician, if so
DO RATE THE SOLUTION
Good Luck
Jan 21, 2011 | Kodak EasyShare Z712 Digital Camera
Lens error on vivitar x327 , lens wont go in
Hello
Good Luck
Jan 10, 2011 | Vivitar ViviCam X327 Digital Camera
My lens is stuck half way out of the camera, when i try to turn it on it says there is a lens error. i have tried all of the suggestions, what else could it be?
Hello
Good Luck
Jan 06, 2011 | Nikon COOLPIX S610 Digital Camera
CAMERA LENSE WILL NOT RETRACT.
Hello
Good Luck
Jan 02, 2011 | Canon IXUS 80 IS Digital Camera
The lens on my canon powershot A480 will not retract, I have tried to restart the camera but this does not work, I have a 'lens error' restart camera' message but this does not help
Hello
Good Luck
Jan 01, 2011 | Canon Powershot A480 - Silver Digital...
When u turn on camara it says lens error and shuts off and the lens wont go in
Hello
if so DO RATE THE SOLUTION
Good Luck
Dec 24, 2010 | Sanyo Vpc-s1070w Digital Camera
Cannot close lens
Hello
Good Luck
Dec 22, 2010 | Kodak Easyshare C813 Digital Camera
Camera repair shop in Panaman City, FL 32408 The
There could be several reasons for the lens stuck out. Try the steps below and check if they can fix it.
However following the steps below may worse or cause more damage to your camera.
I had this same issue, the lens was stuck out. I pushed the lens gently left, right, up, down and pushed the zoom button and eventually the zoom worked and pulled the lens in and now it functions as normal. Good luck!
Step 2.
I'm a completely a-technical guy, but without anything to lose I opened it up (4 screws, 1 of 'em next to the batteries).
Inside, I lifted the black hatch on the bottom left of the lens. (2 screws). There are 6 (white) cogs of different sizes underneath, which connect to the main (black) cog which extends the lens. Under the white cogs is the motor for the lens, but unless you get absolutely no buzzing or anything when turning the camera on (which would mean your motor is toast) you don't need to go there.
I made a schematic drawing before taking out all the little cogs and sprockets and whatnots. I cleaned them one by one with a needle and put them back using tweezers. I tested it by pushing the main (black) cog with the needle, clockwise, and pulling out the lens manually. It came all the way out, whereas before it didn't, so I closed it back up, and it was fixed!
If the above steps does not fix, follow the below steps.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some obvious potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #6a: This is a variation of Fix #6, and should be tried if the lens barrels appears straight (not crooked). In other words, try this if there's no obvious mechanical damage to the lens barrels that's causing the problem. With the lens pointed down, try "gently" tapping around the lens barrels with a small item such as a pencil or a teaspoon. The idea is to try to dislodge any sand particles that may be jamming the lens barrel stuck. Simultaneously try turning the camera on and off as you're doing this.
Fix #7: The most extreme of the fixes. You especially might consider this if the lens barrel appears obviously damaged, bent, or crooked such as from a fall. Try forcing the lens. More people have reported success with this method than with any of the other methods (see the polls in the right column). HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 07, 2010 | Sony Cyber-Shot DSC-S90 Digital Camera
Sand in Lens of Olympus Fe-310 Digi Camera?
Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
or
Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Jun 14, 2009 | Olympus FE-310 Digital Camera
Stuck
Could it be that there is something stuck in the lens barrel? Possibly grit of some sort? I would suggest pushing the lens in gently until the front shutter closes, then try to power on again, if this works and the barrel extends try to inspect for dirt in the barrel and get it out.
Feb 16, 2008 | Samsung Digimax S800 Digital Camera
Fujifilm Finepix S2980 Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
