Question about SAMTRON 55V 15" CRT Monitor
Problem with opening monitor cover
Hello, i am using samsung samtron 55v model crt monitor. and i want to open the back cover of my monitor.. i detached both the clips in the bottem and still there are some clips on the top.. how can i open the cover? please help me..
  • 3 more comments
  • madmiths Dec 03, 2007
    hello i need to remove the back cover, i remove two screws but still its not. is there any locks
  • Anonymous May 16, 2008
    i am facing same problem in Samtron 56V
  • ssankar May 18, 2008
    i cant open back cover
  • ndero-14 Jan 27, 2009
    kam problem me monitorin shum kadale po puno edhe vruset spo hke kallxom qish
    kam problem me ekarni shu, i lisht
To remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Posted on Jan 25, 2009
    Problem Solver:
  • 5 Answers
Please open the top side clip with smallest screw driver (that means a aligner). first remove bottom clip and then see the two small gap in the top side.and insert aligner in the gap and u got the clip in the gap press through the aligner smoothly.at the same time u will pull up back cover in bottom side.cover will come up smoothly.bye
Posted on Feb 23, 2009
There are 2 hidden clips inside at the top and i had to use a flat object to do this. Slight damage to the facia at the top is unavoidable as it was trial and error with a touch of sheer determination for me.
Posted on Jan 04, 2008
Hi its very simple to open a 56v and 55v model in samtron please follow the hints
Posted on Mar 02, 2009
SOURCE:
I have samsung syncMaster 551s CRT monitor. i want to open its back cover. i found only two scrow and i have remove them. but now problem is i cant remove it. plz help me.
You have to find 2 holes at the top of the plastic cover (at the front edge of the back cover) of this monitor and place a flat blade screwdriver in them and gently press to unlock the cover.
Sep 22, 2010 | SAMTRON 55V 15" CRT Monitor
How to stop monitor menu pop up in my Desktop's CRT Monitor ? The menu pop up keeps coming back and I have to keep exiting manually using monitor menu buttons.
r u sure about model number.bcoz 55v does't come with menu.
replace regulator 7805 near microcontroller if it is model 56v.
Aug 22, 2010 | SAMTRON 55V 15" CRT Monitor
I can't open Monitor
there will be 2 plastic lugs on the top of the monitor. using a flat blade screwdriver you can undo these
May 12, 2010 | SAMTRON 55V 15" CRT Monitor
How to open back cover of samsung 55v moniter
Read somewhere that you need to insert a blunt screw driver in the slots between the cover and the the top of the front cover and press down lightly. hope this helps...
Feb 01, 2010 | SAMTRON 55V 15" CRT Monitor
Removing back cover of samsung monitor 15'' crt 55v
I need some solutions to remove back cover for the CRT samsung monitor
Jan 17, 2009 | SAMTRON 55V 15" CRT Monitor
I have a Samsung CRT monitor, every time when I switch it on it constantly changes the colors for atleast 20 min... after that it just works fine. is there any options to service or changing the monitor...
Sounds like the monitor have a "cold joint" or having issues with overheating parts. I believe your monitor was used for long periods of time with no power saving active.
If you are a technician and are planning to fix it, you need to solder all cold joints. Also maybe the filaments inside the CRT are reaching the end of it's life.
Instructions how to open the samsung display: http://josepino.com/?open-samsung-back-cover
Dec 22, 2008 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15 in.CRT
If the power cable is detachable, you can check it for continuity with a multimeter.
If you are aware of the hazards of imploding glass, high voltage, and x-rays, you might consider opening the monitor to replace a fuse.
May 23, 2008 | SAMTRON 55V 15" CRT Monitor
Cleaning inside of monitor
i never heard of cleaning a moniters internals. but yeah go ahead. use a artist medium paint brush and compressed air. watch out for compassitor it will still have a live charge even if unplugged.
Feb 03, 2008 | SAMTRON 55V 15" CRT Monitor
HOW TO OPEN COVER OF OVERSIDE?
first remove back side lock then take small pin like tuser insert into small hole & Push it up side it will open
Nov 14, 2007 | SAMTRON 55V 15" CRT Monitor
Samsung SAMTRON 55V
just find it on http://www.eserviceinfo.com/download.php?fileid=4374 just vote for me so that i can help u again
Aug 29, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
594 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
