Question about Lenovo Computers & Internet
0210 stuck key 4f on lenovo T400 - Lenovo Computers & Internet
3 Suggested Answers
  • 561 Answers
SOURCE: when starting my Lenovo Think Pad laptop T400
Hi
Thank you for your query
Please try the following
1) Hook up a external keyoard to the USB/PS2 prot and see what happens
2) Press all the keys several times when the laptop is switched off to ensure that the keys are not stuck i.e. with debris etc etc
if this fails it would seem you have a bad keyboard, and would be looking at getting replaced
Please leave feedback/vote if my answer was helpful
Posted on Feb 12, 2010
tagmonkey2k
  • 117 Answers
SOURCE: Error 0210: Stuck Key 01
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset. If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
Posted on Apr 19, 2011
Lenovo R400 Error 0210 stuck key 5b
Stuck key error means that one or more keys on the keyboard are stuck. It's possible that a liquid spill can also cause one or more keys to electrically "short" causing the error. Inspect the keyboard and check if any keys are mechanically stuck.
If you're mechanically handy you can remove the keyboard, inspect any chances of damage or corrosion. Plug it back and see if error is still occurring.
Reset BIOS to default settings. Perform Flee Power - remove the battery and any other peripheral device connected to the computer. Hold the power button for 10-15 seconds and then connect only the AC Adapter and turn ON the computer.
Aug 19, 2016 | Lenovo ThinkPad R400 Notebook
T500 - error 0210 key stuck 3C
It sounds like a stuck key on your keyboard. You can try dusting off the keyboard with compressed air. If you see any dirt or debris you can try to remove it gently from the keyboard. You may have to replace the keyboard. If that is the case you can replace it yourself or have someone competent do it for you.
Jul 16, 2014 | Lenovo ThinkPad T500
Fix error code 0210 stuck
error0210 is probably the O key. I found this information from Lenovo Service Site. Hope it is usefull.
You can test your key codes on this site, and as others have already discoverd and from my past experience key code 28 indicates that your error is coming from the apostrophe key. Sometimes due to normal use, keyboards may not fully release a key after it has been pressed. I would recommend getting some compressed air and try cleaning the keyboard, it is possible something is stopping it from releasing.
Since it seems that you are having mulitple errors I reccomend is to verify that your drivers are up-to-date, you can do so from the Lenovo Driver Matrix.
However, if this does not fix your error, it is possible the error has something to do with the BIOS Settings. You may boot to the BIOS and set it back to factory settings and check if the issue persists. To enter BIOS press the F1 immediately after the logo screen appears. Prior to the reset back up all of your information so that you do not lose anything as a precautionary measure.
Also, as others have stated if your device is under warranty, you may contact your local Lenovo Service Center for further assistance.
Dec 11, 2013 | Lenovo ThinkPad Computers & Internet
When starting my Lenovo Think Pad laptop T400 there is an error message 0210 stuck key 50, what does this mean and what shall I do
Hi
Feb 12, 2010 | Lenovo ThinkPad T400 PC Notebook
Oct 17, 2009 | Lenovo ThinkPad R61i Laptop
How to remove and replace keyboard key on Thinkpad T400
Here is a pdf file of your service manual, make sure to save yourself a copy on your drive for future reference.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/43y6629_04.pdf
Oct 02, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
ERROR CODE "0210:KEY STUCK 39
I got the 0210 stuck key error on a Lenovo Thinkpad T61, pc would not bootup, made sure keyboard was connected and cleaned with aircan and then went into bios and via F1 on startup, then went to CONFIG then to Keyboard/Mouse then I disabled the TrackPoint. Boots up fine now but the red nipple mouse is disabled due to action mentioned above. Looks like a warranty fix for Lenovo since this is a newer laptop. If it was out of warranty i would just skip using it and leave it disabled. The trackpad works fine.
Apr 27, 2009 | Compaq Presario 1200XL111 Notebook
Problem .......x61 tablet help !!!!!!!
Hello snapshots,
I have an x61, and you may want to check that all of the keys on your keyboard are not damaged, and that none of them are stuck in the pressed position. That is what the "stuck key" message typically means. If you check out the keyboard, and all the keys are fine, and if you are still receiving this message, try calling Lenovo support. There is an off chance that your keyboard (or other components) may be slightly defective.
Here is the link to the Lenovo site: http://lenovo.com/planetwide/select/selector.html
Hope this helps!
Jeff
Feb 27, 2009 | Lenovo ThinkPad X61 Tablet PC
Computers & Internet Logo
502 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
