Question about Samsung NX1000
No screen can be seen when switch on
When switch off, the LED light still on.
Samsung UN55EH6000 has audio, but no backlight LED as seen with flashlight test.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 29, 2016 | Samsung Electronics UN55EH6000 - 55in...
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Can't Find Correct Pull Chain Switch I have a new bathroom wall sconce that has a two lights - a regular bulb and an LED night light. The pull chain switch for it broke and no one at Lowes or Home Depot...
It's called a "momentary switch, normally closed". This is sometimes abbreviated Mom Switch, NC. But I have never seen one with a pull chain before. Maybe you can find one with a toggle that you can attach a chain to.
Good luck.
May 06, 2010 | Electrical Supplies
When i switch on the psp,the power led(green led is seen,but nothin is seen,and when i try to switch off the psp the green light stays as it is and only removing the battery will turn the psp off..soo is...
have you tryed to put the main power cord in and see if it will boot as normal ?
some people have modded psp and there battery could be a parnora battery need for modding psp that will give you the green power light and blank screen
also take out any memery stick
and try
what is your firmeare numbers / letters ?
Sep 29, 2009 | Sony PlayStation Portable (PSP) Console
Won't switch on
What brand TV is this? Sounds like the power board may be out. You could check for power at the power board with a Multimeter. You need to have power run to the TV but TV not powered on. Board usually has a led green or red light to indicate power to the board. Sometimes this light can be seen without taking the cover off, sometimes you may have to remove cover to see power board and definitely to test with multimeter. Hope this helps. J
Apr 08, 2009 | Televison & Video
LED Brake Lights diming
I had the same problem with my 2004 TL, and it was the brake light switch. It is very easy to replace. (10 min) I ordered one from Rockauto.com for only $6.95. To replace: Remove the black cover under the steering wheel, down by the fuses (held in place by rubber pins and clips - no screws) Locate the switch on the arm of the brake pedal. Unplug the switch, twist the old switch out and install the new one - it's simple!
Aug 05, 2008 | 2004 Acura TL
Samsung NX1000 Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
