SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
SOURCE: Pool heater will not turn on.
It means that there is no pressure in the pipes to indicate flow. Make sure that water is flowing, and if there is a bypass on the heater make sure valves are in the correct position to allow water to flow through the heater. If you are CERTAIN that water is flowing through the heater, and the LCD still says no flow, you probably have a faulty pressure switch inside the heater, which is the most common problem with pool heaters. To confirm you will need to remove the wires from the pressure switch and short them together with another piece of wire. If it still says no flow you may have a bad board, but 99.9999% of the time it is the pressure switch.
SOURCE: where is the pressure switch located so i can replace it. lost my manual
open the lower front door, then up on underside of panel are two screws/hex head. Unscrew these two screws and the upper panel will slide down, may need a gentle nudge. Near the middle left your will recognize your pressure switch.....
SOURCE: owners manaul for SR400NA
If you have not received an answer to this issue, you can find an Owner's Manual online at:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
I hope this is helpful!
SOURCE: Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
