Question about MagLite XL50
Disassemble tailcap
I want to replace the switch cover
Where do I find the model # on a flashlight I have?
On the packaging that came with it.
Written on the side, the tailcap or the lens housing.
In the confirmation email if you bought it online.
Why do you need to know?
Mar 07, 2018 | Camping, Backpacking & Hiking
How do i open the flash light to change the batteries in a duracell 500
This query is not really relevant to Cameras, now is it, dear ? Have you looked in the manual ?
Oct 01, 2017 | Duracell Cameras
Have a utility here 1000 lms flashlight that stopped working. Replace nine aa batteries and still not working what should I try next
1st go back and verify that u installed them correctly , lights nowdays have a specific way the cells go in them or they don't work
2nd try a new light bulb (if it has one) bulbs do go from time to time u know
and last try fiddling with the battery cover , some lights have a tricky way the covers go on !!
Dec 20, 2016 | Camping, Backpacking & Hiking
How do I access the battery compartment on model 06443
To change the batteries in your flashlight, unscrew and remove the base tailcap, as the end that doesn't have the light. Remove the battery holder, replace batteries and then replace the battery holder in the same way that it was taken out (spring first).
http://ledmuseum.candlepower.us/fourth/gled.htm
Feb 21, 2015 | Garrity Camping, Backpacking & Hiking
How do I change a battery on an Energizer TUF2AAP
Unscrew tailcap and pull out a battery module. Load 4 AA cells into module and re-insert.
Nov 30, 2014 | Energizer TUF2AAPE Hard Case Pro...
I have a 98 blazer 4wd emergency lights switch
If you purchase the complete multifunction switch to repair, you will need to disassemble the column covers and steering wheel to access the screws. If you purchase just the hazard switch (sometimes available from GM), just remove the upper cover and use a pocket screwdriver down the side to release the lock tab. Then insert the new switch and reinstall the cover.
Sep 24, 2014 | 1998 Chevrolet Blazer
How do you open the flashlight to replace the battery?
You have to unscrew the end tailcap. Remember, unscrew it counter clockwise, and when replacing the batteries keep in mind the polarity.
Feb 20, 2011 | Surefire E1L Outdoorsman E1L HA Flashlight
Flashlight only works when end cap is partially on. Will not work when cap is fully screwed in. New batteries installed.
Some models of the famous MagLite use this 'feature' as the on-off switch. I have several such myself.
Thanks foryour interest in FixYa.com
please remember to vote
thanks
a
Dec 05, 2009 | MagLite 3 Cell D Blue Flashlight S3D116
I have a Streamlight Strion Xenon compact flashlight that has served me well for two years. Recently the 'twist to stay on' feature has failed. The 'push the tailswitch on' feature is still functioning,...
Ray, sounds like the switch has a problem. Streamlight is usually really good about fixing things. If you can drop by a Stream retailer in your area, they will probably give you a new tail cap. Or contact STREAM directly.
One thing, when you screw the tailcap tight, does the light come on? I have a SUREFIRE that does that, but I dont have a twist on Streamlight.
Sep 27, 2009 | Streamlight Strion 12V DC Only
How to replace headlight switch 1994 toyota corola
you have to take steering column/cover apart to disassemble the unit. once you have the steering cover apart, follow the wires to locate the plug. unplug the old headlight switch and plug in the new one. no need to take steering off, very easy to do.
Jul 11, 2009 | 1994 Toyota Camry
MagLite XL50 Logo
107 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
David Black
David Black
Level 1 Expert
 steve
steve
Alec Oren Orris
Level 1 Expert
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
