Question about Pioneer Audio Players & Recorders
Pioneer iCONTROLAV12 app Error code B57113 Fix. - AVS Forum
How to fix rom error
pioneer sucks, when it comes to defect tables, ;i'll never use them, search on the pioneer forum is my suggestion.
Aug 09, 2014 | Pioneer CDJ 1000 Mk3 Turntable
My Onkyo FM/AM tuner amplifier r-30 becomes very staticy when I turn to the phono but is fine on FM and AM radio
Check your connections to make sure that the cables are tight and that there aren't any stray wires that may be shorting to other terminals on your amp.
If there's nothing there, may I suggest you take a look at AVS Forum's amp forum:
Receivers Amps and Processors AVS Forum
You can either find a solution there, or, post your problem and get informed responses.
Jul 28, 2014 | Audio Players & Recorders
Error code b47110 pioneer icontrolAV2 app ios
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 01, 2014 | Pioneer Audio Players & Recorders
No sound from subwoofer
From somneone on the AVS-forum I got the tip to set the front speakers to small. After checking this (it was set) I looked after the sub (a Fostex PMsub) again and turned the volume really high - and now it works! Of course I have tested the sub on another output (other amp and zone2-out on the Onkyo) and it worked with a relatively low setting. So it seems, that the sub-out is just very low level, but working OK.
hth
Karl
Dec 05, 2012 | Pioneer VSXD814 Receiver
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
Pioneer BDP-f1FD Disc Tray Won't open
I fixed this on my unit from a tip on AVS Forum
Unit has "Power on" msg, follow these steps:
1) Hit power button for 5 -10 sec unitl unit shuts off
2) Press open / close button unit or remote first (do not hit power button first)
3) On the third try, the disc tray opened
I had James Bond Goldfinger in the player ( not sure if this had anything to do with it), I put another Blu Ray in and it loaded fine and is playing fine, hope this works for you
Dave
AVS link below
http://www.avsforum.com/avs-vb/showthread.php?t=1054927&page=413
Apr 20, 2009 | Pioneer BDP-51FD Blu-Ray Player
604 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
