Question about Samsung Illusion for Verizon Wireless
Micro sd card
My phone says I don't have a sd card but i do how do I fix problem
Raysagem
  • 1017 Answers
SOURCE: turn off write protection on a sd micro card
In the menu, tools, memory card, options you should find the setting for memory card password on/off
Posted on Jan 04, 2008
patel352003
  • 192 Answers
SOURCE: micro sd card not reading songs
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me patel352003@gmail.com or patel352003@yahoo.co.in
Posted on Jan 07, 2008
ipodfreek
  • 64 Answers
SOURCE: Transfer music from computer to phone
When you put the SD card into your laptop, it should show-up as a hard drive (one of your drive letters on a Windows machine).
Copy or drag your music files from your computer's hard drive to the "music" folder (it might be named "audio", I can't recall) on the SD card. This folder should be there if the card was previously in your phone. Once the files are copied there, they should play on the phone.
If you still have problems, try reducing the bit rate on the music files. I'm not sure how high of a bit rate this phone can handle.
So, for example, if your music is encoded at 256kbps, try reducing them down to 192kbps. I'm not 100% on this, but it's worth trying.
Good Luck!
Posted on Feb 01, 2008
  • 40 Answers
SOURCE: saving music on my micro sd..
well assuming you loaded music on your sd card:
to find it, just go to mystuff....
menu, mystuff, center button, it should load the mini sd right there. then all you have to do is click over right and file explore the mini sd. you should put music in the music file.
another option on the phone.....
go to att music
menu, upper left icon, center button, music player, it should find all files.
let me know how i can help some more
Posted on Feb 24, 2008
  • 6 Answers
SOURCE: need to reformat micro-sd card in up stage phone
to reformat micro sd card in your phone
go to menu>my stuff>select removable disc or memeory card then select options>format
>>or you can reformat the micro sd card using your pc
>>connect the sd card to the memeory card reader then connect it to the memory card adapter
>>go to my computer then select removable disc then right click then select format
Posted on Feb 28, 2008
How do i transfer my photos from my kin one to the computer? when i plug in the usb cord it says i need a driver software, which i don't think it came with
If your photos are stored on a micro or mini SD memory card then -
An alternate method is to remove the mini or micro SD memorycard from the cell phone and insert it into an USB card reader then connect itto the USB port on your computer. Youcan then open the photo folder on the micro or micro SD memory card and copythe photo to your computer.
Sep 10, 2011 | Microsoft KIN One Cell Phone
My lg800ghl doesnt except my micro sd card.tried formsting but still doesnt work and i get the micro sign with an x in the top rght cornor
Only a 4GB Micro SD works with this phone. I first tried a 16GB and it didn't register at all, but the 4 does. By the way, finding the Micro SD slot is also hard to find at first. It's located under the battery.
Aug 25, 2011 | LG KE800 Smartphone
WHERE DO I PUT THE SD ADAPTER
Hello.
You don't need the SD adapter in your mobile phone. You may use it by inserting the micro SD card into the SD adapter, then insert the SD card adapter in a "SD card reader" and use it in a USB slot in your computer to access files from your "micro SD card".
I hope this helped you.
Thanks for using Fixya!
Please rate my answer.
Aug 04, 2011 | HTC Hero Smartphone
How I format micro sd card if MSDC write sector error?
Do this click my computer>right click icon of your micro sd card>choose format (don't check quick format) need full format to recovered bad sector. if finish formating, right click icon of your micro sd card >properties>choose tools>choose error checking and click check now.
To fix your micro sd card.
Also try to scan using anti-virus sometimes virus became write sector error.
Jul 15, 2011 | Computers & Internet
I just uploading the data from my laptop to my micro sd card, it's been loaded but after if we unpluged it from laptop & load it in phone then only one Folder sowing the data & rest are...
Try to reformat your micro sd card using your phone, then plug it into your pc to copy files. Don't forget to properly eject your sd card not just unplugging it. If this doesn't work try reformatting it using your pc then properly eject it.
Jul 02, 2011 | Computers & Internet
I want to format my 3110 phone i need a formating code
hi,
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself.
Jun 21, 2010 | Nokia 3110 Cellular Phone
My mobile 3110c is take so much of time for start
hi,
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself...goodluck ,i hope it will help you..
Jun 16, 2010 | Nokia 3110 Cellular Phone
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
My phone NOKIA 6300 could not find micro SD card. please what do i do?
If it is a 4GB micro SD card it won't work, a nokia 6300 doesn't accept HC (high Capacity) micro SD cards. Maximum you can use is a 2 GB micro SD card.
Don't forget to rate, thks
Oct 28, 2008 | Samsung SGH-D900 Cellular Phone
Memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
Mar 19, 2008 | RIM BlackBerry Pearl 8100
Samsung Illusion for Verizon Wireless Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
