Question about Kenmore Refrigerators
Model 795 7840
Control panel will not stay lit
    Champion:
    Habit-Forming:
  • 279 Answers
I'm not a 100% sure but I think it's supposed to go out after a short time.
Posted on Nov 29, 2013
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
Whirlpool super capacity 465
You may have several things going on f1 e4 is a control board issue with the touch panel plug in into the control board disconnect and reconnect if this problem presist will need a control board and touch pad for the oven not staying lit there is a new oven igniter kit 8190618 unfortunately no good diagnostics for this problem good luck
Feb 18, 2014 | Ovens
Control panel on front stops working, only freezer lights are lit, freezer and fridge stop cooling.
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
Feb 03, 2018 | LG LFX25960ST Stainless Steel French Door...
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Feb 10, 2010 | Kenmore Ovens
Model 211 Dometic, can not keep pilot lit, do I have to have it hooked up to 12 volt
Dometics work on propane, 12 volt or 110 volts, if pilot won't stay lit then you prob have a control board defective. Apply 12 volts and see if pilot stays lit, then you will know.
Oct 16, 2009 | Dometic Refrigerators
Frigidaire slide range clock will not stay lite
I have the exact same problem. Timer works and stays lit, but clock will not stay lit. Any answers?
Mar 05, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Vizio GV47LFHDTV10A No Video No Sound after "POP"!
change the main board first. if you're lucky this will fix the problem if not your inverter is dead.
Mar 03, 2009 | Vizio GV47LF Television
Refrigerators Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
