Question about Savv LM-S6000 Car Monitor
SAVV LM-S6000 monitors NTSC/PAL
My remote has been stolen, and I need to change the NTSC/PAL settings on my LM-S6000 monitors. How can I do this, or where can I buy a new remote? The problem is that my new DVD player plays in auto mode, and the monitors are set to NTSC, so I get a black and White picture whit lot of disturbance. I am not able to change these settings on the DVD player. This is a JVC AVX33
2 Suggested Answers
SOURCE:
  • 47 Answers
SOURCE: Need a remote for the SAVV LM-S6001
SAVV .COM
Posted on May 13, 2008
DVD Player works only on NTSC color(NTSC Idicat on display unit).but VCD have normal color.I am tried to change color to PAL with remot controler.but it's not working.
If your TV set plays both NTSC and PAL, there shoud not be a problem, as it sets the color system automatically. If your antenna video signal is passing through the receiver however, instead of going to a VCR and then back to TV, there should be a problem there. The cable going from receiver to TV (AV1 or AV2) is the one marked as "monitor" on the receiverĀ“s rear panel.
Sep 19, 2010 | Audio Players & Recorders
I want to play an NTSC tape on a PAL television
This is a VCR alone machine?Not a DVD and VCR combo?VCR alone machine dosen't have auto NTSC/PAL setting to play all the world regions.
May 28, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
How do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Mar 17, 2009 | Audio Players & Recorders
When I hook my playstation 2 to my trutech tv, it plays in black and white. How do I get it to play in color?
You need NTSC TO PAL converter or a RF converter for this problem.
your console must be of NTSC type and your TV PAL type or vice versa.
check your tv settings to change from pal to ntsc to get color. Mostly modern TV sets would have the settings to change on their remote controller from ntsc to pal, secam etc.
Dec 18, 2008 | Bethesda Softworks Black & White
Need video jack
I interfaced the SAVV LM-S6001 today. Here's what I found;
Looking straight on at the male 8 pin DIN connector here's how I'll describe it. There are 3 pins across the top row. From left to right I'll call them 8, 7, 6. There are 2 pins on the left side of the middle row, 5 leftmost and 4 adjacent to the center. Moving right, there is a gap and then pin 3 on the rightmost side of the middle row. There are two pins on the bottom row, pin 2 on left and pin 1 on right. Draw that on some paper.
8 7 6
o o o
5 o o o 3
o o
2 1
Pin 1 is +12VDC
Pin 2 is center contact of both audio and video RCA jacks
Pin 3 is -12VDC
Pin 4 is outer RCA contact for Video
Pin 5 -n/c
Pin 6 -n/c
Pin 7 -n/c
Pin 8 is outer RCA contact for Audio
Now, I don't know what pin 7 does, but it is wired next to pin 4 suggesting a video application, Svideo is my best guess. I can only test for a composite video connection that I am using.
It's alive!
Jul 09, 2008 | Savv LM-S6001 Car Monitor
Help! I live in CANADA and accidentally clicked the PAL switch on with my remote control the home theater system model DVA - 8700 set-up and now I can here the sound but I can't see anything to find my way...
Pls try doing a reset by unplugging the unit from the mains for a couple of hours (preferably overnight).
Alternately, you can try hooking it up to a video monitor (capable of RCA/Composite or S-video), a movie camera (switch to external video source), or another TV that is PAL/NTSC capable while configuring it back to NTSC settings.
Additionally, you can try simply pressing the NTSC/PAL button with a few seconds interval while playing a known good NTSC disc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Televison & Video
NTSC to PAL
I am afraid this reply is too late, but if you happen to stop by the site: The set has a built-in NTSC tuner, with no PAL tuner, as it is advertised in the US. So the answer is: No, you can't do PAL.
But if your manual says it has the PAL tuner, then you should be able to find a switch on the set or a button on the remote to change over to PAL.
Jan 09, 2008 | LG 17LX1R 17 in. HD-Ready LCD Television
No picture
A blue screen suggests no input signal, or a signal that the electronics in the screen can't handle. I don't think you need the remote, but, it may help. I suggest you try the dvd on a working monitor and check that it's a compatible output. The LM-S6001 is a multi-system monitor both NTSC(US) and PAL(Europe/Aisa). The monitor has a composite video (usually yellow) and RCA(phono) input and DIN, the manufacturer is unclear if both plugs are present. You can assume it's auto-switching, but that may not be the case. More information is needed to fully understand your problem. 1. make/model of DVD. 2. description of external plugs on monitor.
Apr 24, 2007 | Savv LM-S6001 Car Monitor
Savv LM-S6000 Car Monitor Logo
149 people viewed this question
Top Savv Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Savv Car Audio and Video Expert? Answer questions, earn points and help others
