Free mechanical advice online
The lights were left on in my 1996 Ford Escort while at work and battery was drained tried jumping it but only got the dome light to come on assumed that the battery was a lost cause so we bought a new battery but even after installing the new battery we still have no power including lights on the dash and dome light.
  • 7,993 Answers
Post your question in the Cars or Ford cars category.
Posted on Nov 24, 2013
4 Suggested Answers
pagebor
  • 2785 Answers
SOURCE: installing without the CD
for the first part you can check the printer manufacture website for drivers.
visit the hp site
Posted on Jul 21, 2008
rajdeepdutta
  • 2517 Answers
SOURCE: new cartridge installed,screen says out of ink,
Hi there reset the printer and try. If you face same problem then Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Feb 26, 2011
SOURCE: Orange Error light is flashing on printer, have
Have you tried cleaning the ctd sensor? I had this same problem, and using a dry cotton swab over the ctd sensor (located on the inside of the front panel) solved the problem for me.
Posted on May 11, 2011
1997 ford escort battery new battery dead overnight no electrical works no blown fuses jump start and cables start to melt will push start and run
Check battery cables are correct ! Prime suspect here ! Alternator may be damaged and shorting .. Don't drive any car that will melt jumper cables ! Something very basic wrong here.
Aug 26, 2012 | Ford Escort Cars & Trucks
Need timing belt dieagram for 1996 ford escort
http://www.ebooksquad.com/search/free+online+1996+ford+escort+engine+diagram
Stumbled across thise site, not sure if it is reputable, but it looks like it has wha you need.
Feb 02, 2011 | Ford Escort Cars & Trucks
P-reg 96 escort, my battery is dead after only a few hours however when the car is running (after jump starting it) the immobilisor light comes on for about a minute, then starts to flash every 3 seconds....
Bad Alternator.
After Starting or Jumping your vehicle: Remove the Negative Cable from the Battery.
If the Engine dies or runs really rough it is a bad Alternator.
The Battery Starts the Engine and runs nominal operations. The Alternator runs the Engine after it is Started by the Battery.
If the Engine does not die or runs really rough after removing the Negative Cable, then you have a malfunctioning Battery.
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Feb 25, 2010 | 1996 Ford Escort 4 Door
I have just had a new batt and altenator fitted to my 1.8 escort van and the batt keeps draining
It is highly likely that you have a drain.
  1. Check and make sure that the glove box is shutting off the light inside the glove box when you shut the door.
  2. Check and make sure the dome light is set on door or shuts off.
  3. If you have a test light and someone to help, you can check for a drain.
  4. Remove the negative battery terminal and place the test light between the terminal and battery post. If it lights up you have a drain.
  5. With a assistant to watch the test light, go to the fuse panel and start pulling a fuse out one at a time and then replacing, at the same time with the assistant watching to see if the test light goes out.
  6. When the test light goes out you have found you drain.
Jan 23, 2010 | 1996 Ford Escort 4 Door
DO NOT TURN ON ANITHING
Check the battery clamps are tight and good contact, Maybe the battery needs charging, check the fuses.
Jan 15, 2010 | 1998 Ford Escort
2000 ford escort want start. checked fuses and battery . try to turn over but want what can i check. it was running went in house and came back out would not start
Hi
Get a jump start, with good set of leads.
If no joy , follow the Positive lead from the battery to the starter motor, and give it a tap with a small hammer or big spanner, while someone turns the ignition key.
Good Luck !
Remember to give me a FixYa rating....Thanks...John.
Feb 27, 2009 | 1996 Ford Escort 4 Door
Ford escort 1992 wont start
probably the alternator is faulty, change it or have it rebuilt try that hope it works.
Linda
Jan 26, 2009 | 1992 Ford Escort 4 Door
Brand new 08 Ford Sport Trac (2 hr old) - won't start
Sounds like the battery may be bad. You could remove it and take it to a mechanic or parts store and have them test it for you. Mechanic might charge you 15bucks or so. Most parts stores will test it for free and gladly sell you a new one.
Jan 02, 2009 | 2008 Ford Explorer Sport Trac
1999 Ford Escort, no power
Sounds like a bad earth trace they negative connection of the battery and make sure all is good
Dec 01, 2008 | 1999 Ford Escort
20 people viewed this question
jasbo
jasbo
