Question about SMS Audio Audio Players & Recorders
A wire is loose in the left ear - SMS Audio Audio Players & Recorders
Headphone/earphones only left ear plays
Either the plus is not completely inserted (most likely) or a wire is loose or the earphones are damaged.
Mar 07, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
Soul by ludacris left ear cup problem
BEst to just try to find a repair shop for that sort of thing. Disecting headphones is a risky venture, and 9/10 it results in a frustrated, headphoneless user.
Jan 30, 2014 | SOUL by Ludacris Bolt Signature Series...
Sennheister RS120 head phone left ear no sound
Dear friend ,
try to check wiring connection by opening tic tac locks of left side. If there is loose connection solder it .
Sep 30, 2013 | Sennheiser In-The-Ear PC Headset Headset
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
Apr 15, 2010 | Bose Around-Ear Headphones - Silver
Turtle beach x1-other people can't hear me
check if any of the wires are loose inside the thing that turns up the volume. the left and right ear wires are inside of that. i had the same problem with the right ear, all i had to do was solder the wire back on the chip.
Jul 25, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Left ear went out
Sorry fellah, sounds like you've pulled the wire loose from one side. Unless your comfortable with pulling it apart and finding the break in the line, you are going to have to sink the money into a new set. Of course you could always try returning the unit with a reciept.
Nov 03, 2008 | Labtec Curve-460 (50 Pack) Consumer...
Ear phone
It might be due to loose connection of the wires are they are broken.
I suggest you to get a new one.
It cannot be repaired.
Hope you can understand.
Mar 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
No sound in right ear
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Nov 21, 2007 | Technics RP-HP1200 Headphones
35 people viewed this question
Top SMS Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SMS Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
