Question about Fisher and Paykel GWL11 Top Load Washer
GWL15 no hot water on Regular or Heavy Duty Cycles
My brand new GWL15 does not fill with hot water when I select hot water on Regular or Heavy Duty cycles. I get only cool water. If I select hot water on Perm Press cycle, though, I get hot water just fine. I verified that the hot water is on and the hoses are connected properly. I've read the manual 3 or 4 times, and can't find any explanation for not being able to get hot water on Regular or Heavy Duty cycles. Am I doing something wrong, or is the machine defective?
  • fp_troubles Dec 04, 2007
    I get the same behavior. I don't think you're doing anything wrong. I think there's a bug in their control panel though I don't know what the workaround is. This behavior is intermittent, as sometimes doing a regular load does yield the right tempurature water. IF someone has a solution, PLEASE post!!!
  • SandeeWig Jun 06, 2008
    Same thing is happening on my 5-month old washer. In fact, I had not even thought to try another type of wash, as I wash nearly everything on regular; so I appreciated the ability to test ours and see if, in fact, the hot water would run on the perm press cycle, which it does.
    That being said, I find this to be an odd thing with this washer, nothing in the manual to indicate this is normal, and I do not get how the "best solution" listed here is relevant. If I am supposed to have the ability to choose the water temperature, regardless of the wash setting, and I cannot, then the washer does not work properly.
    I think I'm going to call F&P to see what they say.
  • 209 Answers
Should you select a 40* wash it would not be right if the machine filled with hot water, as the water in the house tank is a lot more than 40* ( around 65* i think?) this would just damage the clothes and i am sure you would just complain again at that.
if the machine works fine then there is no problem
Posted on Oct 10, 2007
SOURCE:
What does LF stand for on a Whirlpool Washing Machine?
LONG FILL....I usually means the faucets are not turned on fully OR you have a pinch in the hose and it is taking too long to fill (LONG FILL).
Jun 02, 2015 | Whirlpool Washing Machines
Is it possible to modify the water temps that are preset to the types of cycles? Casual is warm/cold and Heavy Duty is hot/cold. I would like to do cold/cold but it won't let me
You could connect cold to both hot and cold washer connections by using a hose wye fitting . If the hot and cold supply faucets both open together you will have to cap the hot faucet. Hope this helps.
Dec 12, 2013 | Maytag EPIC MFW9700S Front Load Washer
How do i find out whats wrong with my washing machine? The brand is whirlpool heavy duty
check for a clogged filter screen on the cold side of the water inlet valve,the cold water shut off, or the hose kinked
good luck
Feb 28, 2013 | Whirlpool Clothes Washer Heavy Duty...
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain and some cycles won't work
Make sure your drain hose is at least 2ft off the ground if your drain pipe is to low it wont drain
Feb 18, 2010 | Fisher Paykel EcoSmart GWL15
FP Hot water used when cold selected
YOU NEED TO CHECK THE WATER TEMPERATURE AFTER THE TUB IS FILLED WITH WATER WHEN COLD IS SELECTED. NEW MACHINES WILL USE BOTH THE HOT AND COLD WATER VALVES TO FILL THE MACHINE. THEY DO NOT WANT YOU WASHING WITH STRICTLY COLD WATER AS THE DETERGENT WILL NOT PROPERLY DISOLVE. COLD WASH TEMP SHOULD AVERAGE 65-70 DEGREES.
Mar 30, 2009 | Fisher Paykel EcoSmart GWL15
Kenmore 90 Series only agitates on heavy-duty cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 15, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
442 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
