Question about NEAT Receipts Mobile Scanner
I need a device driver to install Neat Desktop Scanner to a Windows Server 2008 Computer
I have a Neat Desktop Scanner and cannot install their driver successfully to a Windows 2008 Server, any suggestions or work arounds for this issue?
I plugged it in and all of the lights come on, but when I press scan, nothing feeds. I hear no mechanical noise like it is trying.
Troubleshooting Scanner Problems in NeatWorks for Windows
www.neat.com/.../troubleshooting-scanner-problems-in-neatworks/
Troubleshooting Scanner Problems in NeatWorks for Windows ... Plug the scannerback into the computer, start NeatWorks, and try scanning again.
NeatConnect Scanning Issues - The Neat Company
www.neat.com/helpcenter/neatconnect-scanning-issues/
My LED screen wont turn on? If this is the first time using the NeatConnect scannerand you are not using it with a computer, please confirm that the cord is ...
Download Neat Software' Activate Neat ' Neat Company
www.neat.com/helpcenter/download-neat-software/
If you are looking to download or activate Neat software for your scanner, visitneat.com/activatend for more information. ... Desktop Software (For Existing Users) ...
Support - The Neat Company
www.neat.com/support/
Neat's Smart Organization System desktop software. ... Fast and efficient scanners to help convert your paper mess into an organized digital filing system.
Jan 14, 2016 | NEAT Desk Desktop Scanner and Digital...
Tip
Windows Server 2008 Network Driver for Proliant ML350 G3
Anyone who has tried loading Windows Server 2008 on their Proliant ML350 G3 has found that HP does not offer the network driver for this system.
BUT, the Windows Server 2003 driver for the NC series Broadcom 1gb will work! Rather than choosing the 'install' option, choose to 'extract' it, then via the device manager, manually install the driver from that location.
Happy Computing!
on Feb 04, 2009 | HP Compaq ProLiant ML350 G3 Server
There is no twain-compliant device installed m1136 mfp scanner drivers not installed on server 2008 r2
It may just not be supported on that OS. Try another OS's drivers and see if it works.
Jan 13, 2014 | Microsoft Windows Server 2008 R2...
I need a workaround to install my HP 5520 printer with a suitable driver to my computer which has Windows 2008 Server R2 as operating system
It is NOT supported.
If you really want a workaround for scanning, you must enable "Desktop experience" feature that is turned off as default. You can then use WIA drivers with MS Publisher or Photoshop or acrobat or paperport to scan.
Nov 24, 2013 | HP Photosmart 5520 e-All-in-One -...
Windows server 2008 drivers for celsius r610?
That system has support for windows XP and Linux (RedHat and SuSE) so if you want to install windows server 2008 you will need windows 2008 compatible drivers, maybe this link bellow can help you to identify right drivers (It is detailed technical motherboard manual for that system)
Manual
Mar 15, 2013 | Fujitsu Siemens Celsius R610 PC Desktop
Scanmaker 3830 driver for windows 7
this helped me with my scanmaker 3830 on windows 7 and windows 8 64bit too
You can download: ScanWizard 5 version 6.63 Here: ftp://microtek:microtek@files165.cyberlynk.net/microtek/pcfiles/drv_sw5_v6_63_ad.exe
Extract to folder on desktop. 1. Plug in your Scanner 2. Go to Control Panel (Windows 7,8 - 64 and 32 bit) 3. Go to Device Manager 4. Go to Imaging devices (or Other devices) 5. Find what windows have installed Right Click 6. Update Driver Software.. 7. Click - Browse my computer for driver software 8. Click - Let me pick from a list of device drivers on my computer 9. Click - Have Disk 10. Browse to your desktop or position where you extracted 6.63, point to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I picked first 11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800 then USB 2.0 and both works., install the scan wizard, restart the computer
Jun 25, 2012 | Microtek scanmaker 3840
Problems installing Neat Receipts
You need to install Microsoft SQL Server Compact 3.5 Service Pack 2 from MS web site:
http://www.microsoft.com/en-us/download/details.aspx?id=5783
Steps:
1. Download installation package from above link and save them to the desktop or other folder
2. Start that .exe and unpack to some folder on your PC (or that same folder)3. Open that folder and run BOTH installations for Windoxs x64 PC - first start:
SSCERuntime_x86-ENU.msi and then
SSCERuntime_x64-ENU.msi
4. This would install necessary SW and then you could re-insert Neat CD to start the installation which would proceed now.
Mar 06, 2012 | NEAT Receipts Mobile Scanner
About ibm server x3400 drivers
You can download the drivers from IBM's website:
http://www.ibm.com/support/us/en/
Aug 31, 2009 | IBM x3400 Server
Cannot detect other printer in remote desktop connection
Hello my friend, regarding on your problem kindly check your system particularly your windows 2008 server OS. Kind reinstall the printer drivers then then shared it. Then after you share the printers kindly check the ip address of your windows server 2008 OS then go to the workstation Computer then click start button found in your task bar manager then click run. Then kindly type the "\\IP of your windows server 2008" where your printer drivers installed then enter. As soon as you can log in the Windows server 2008 menu environment then if you can find or see the printer icon then click the printers icon then right click then click connect. Let the system automatically installed the printer driver to your workstation computer. then as soon as your system finished installed the printer drivers then try to run and print if you can now print using network LAN.
Hope this solution able to solve your problem. If you need more assistance kindly rely to this post.
Thank you.
geo_jonas
Jul 17, 2009 | Office Equipment & Supplies
NEAT Receipts Mobile Scanner Logo
Top NEAT Office Equipment & Supplies Experts
Steve F
Are you a NEAT Office Equipment and Supply Expert? Answer questions, earn points and help others
