Question about FelPro 1981 - 1990 Toyota Pickup EGR Valve Gasket 72559 Toyota EGR V
88 toyota p/u hesitate about 55 miles an hour and at the top of each gear
My 88 Toyota Pickup hesitates around 55 miles per hour and also At the top of each gear. The timing marks are all on a double and triple check them. Was wondering if it may be the EGR valve
    Genius:
  • 1,198 Answers
Your vacuum lines are ancient. Check all of them, and then check the system with a vacuum gauge. Handy tool to have.
Posted on Nov 24, 2013
I have a 2003 toyota 4 runner sport, runs great in town and at 55 miles per hour, but on hwy at 70 + miles her hour it over heats why?
Water pump isn't moving enough water at the extra highway speeds. I've seen toyota water pump impellers wear down and sometimes it slips on the shaft. Look at replacing the water pump.
May 28, 2016 | Toyota Cars & Trucks
How do i change the speedometer on 1998 Avalon from kilometers to miles per hour ?
install a spedometer with kilometer markings or manualy paint markings on at proper locations. 88 kph = 55 mph, etc.
if you were thinking you could push a button, not gonna happen.
Jul 01, 2014 | 1998 Toyota Avalon
2000 Toyota solara 6 cylinder seems to hesitate between 45 and 55 mph
ever do the 60k mile tuneup? this decade?
if it does run perfect
and only hesitates for a second (you never said when)
you TIP-IN the throttle. and it hesitates for a very short time (1s) and
then catches up (does it) and WOT is good power.(wide open throttle) up a hill
then that is a BAD TPS. Hard to test and ECU never reports
it for one good reason, the ECU thinks the driver is crazy
so ignores it, (some times driving crazy is justified) see?
like passing, and should not be...
the TPS gets worn and it fails to report your fast foot
and the ECU fails to activate Enrichmode,
the Air meters. catch up, and power returns.
i can test any TPS , i have a scope, to see the glitch failures
most shops just replace it on suspicion.
Jan 14, 2014 | 2000 Toyota Camry Solara
I have a headset a shin at 55 miles per hour and a top of each gear. timing is good I checked it and double check it. was wondering if it may be the EGR valve
Not sure of your question. Could you ask it again? Want to help but need more info or restated in a different way.
Nov 24, 2013 | 1988 Toyota Pickup
Automatic transmission hesitant or won 't upshift
transmission rebuild time the clutch disc are burnt all ready
Jul 20, 2013 | 1987 Toyota Pickup
My 1999 88 LS has a vibrating sound when driving from 35-55 miles per hour and is loudest when going 50 miles per hour. I had the tires replaced and the car rebalanced but the car still makes a vibrating...
check the axle shaft assy,an excessive joint angle due to incorrect toe-in or trim height,,,,,Wm or damage inboared or out boared joint,,,,,,,A sticking spider ( tri pot joint)
Jul 03, 2010 | 1999 Oldsmobile 88
1986 toyota 4 runner..2.4 efi automatic...has a slight hesitation-miss under acceleration..just been tuned up and didnt cure problem any ideas?
1-Replace fuel filter.
2-Clean injectors
Most of the time an hesitation on acceleration is due to fuel.
May 19, 2010 | 1986 Toyota Pickup 4WD
Throttle hesitation
If you have no vacuum leaks, the injectors could be clogging up (winter gas or old gas can cause that) or the throttlebody may need cleaning. Use the correct cleaner that is O2 sensor safe! Also ensure the air filter is clean.
Mar 23, 2010 | 1991 Toyota Pickup
TOYOTA COROLLA KICKS AT 10 MILES PER HOUR WHEN ACCELERATING
Hi. the car is kicking due to the 1st to 2nd gear upshift in the transmission. Corollas are famous for this kind of behavior when it comes to the transmission. Some of them kick when upshifting, some of them downshifting, And some of them make a humming sound when they do so. It doesn't mean the trans will fail. Just make sure you do the usual fluid checks, and as long as it still look purple, you'll be fine.
Jun 27, 2008 | 2005 Toyota Corolla
FelPro 1981 - 1990 Toyota Pickup EGR Valve Gasket 72559 Toyota EGR V Logo
Top FelPro GPS Experts
Are you a FelPro GPS Expert? Answer questions, earn points and help others
