Question about NCR Computers & Internet
7402 black screen - NCR Computers & Internet
Do you have tthe drivers for the credit card readers
hope this helps
http://www5.ncr.com/support/support_drivers_patches.asp?Class=External\display
Jun 02, 2014 | NCR 7402-1020 Pos Touch Screen-point Of...
Error on display call service 7402:0005942
The machine is not detecting the cyan developer unit . I would first try reseating the unit or replacing it.
Jan 29, 2014 | Kyocera FS-C5100DN Color Laser Printer 23...
CALL SERVICE 7402
Error code 7402
Developing unit C noninstalling error
No density detection signal is output from toner sensor C in developing unit C.
Reinsert the connector. Also check for continuity within the connector cable. If none,
replace the cable.
Developing unit C and Drum relay PWB
(YC10)
Drum relay PWB (YC1) and engine PWB
(YC34)
Long story short, the printer MUST go in for a service as you will void ANY warranty if you try this yourself, it is an electronic failure.
Feb 09, 2013 | Kyocera FS Office Equipment & Supplies
I would like to know how to create folders for apps and other data.
S/N: 1045-0640-7570-6160-0674-4577 or s/n: 1326-0110-5569-6121-4741-2255 or s/n: 132606517402042440668309 or Name: waters s/n: 13724000812 or s/n: 1326-0651-7402-0424-4066-8309 or s/n: 4343-2344-9803-8904-3378-9432 or s/n: 1329-0352-5602-3552-´510-1754 or s/n: 1329-0267-4911-3894-4929-5767 or s/n: 1326-0651-7402-0424-4066-8309 or s/n: 132607508173996638955607 or S/N: 1326-0651-7402-0424-4066-8309 4343-2344-9803-8904-3378-9432 1329-0352-5602-3552-4510-1754 1329-0267-4911-3894-4929-5767 1326-0651-7402-0424-4066-8309 or s/n: 1326-0651-7402-0424-4066-8309 or s/n: 4343-2344-9803-8904-3378-9432 or s/n: 1329-0352-5602-3552-s510-1754 or s/n: 1329-0267-4911-3894-4929-5767 or s/n: 1326-0651-7402-0424-4066-8309
Sep 17, 2011 | ASUS Eee Pad Transformer TF101A1 Tablet...
Hi i need the activation code of photoshop cs3! please!
photoshop cs3 S/N: 1045-0640-7570-6160-0674-4577 or s/n: 1326-0110-5569-6121-4741-2255 or s/n: 132606517402042440668309 or Name: waters s/n: 13724000812 or s/n: 1326-0651-7402-0424-4066-8309 or s/n: 4343-2344-9803-8904-3378-9432 or s/n: 1329-0352-5602-3552-´510-1754 or s/n: 1329-0267-4911-3894-4929-5767 or s/n: 1326-0651-7402-0424-4066-8309 or s/n: 132607508173996638955607
Photoshop CS3 CS3 Name: serial photoshop CS3 MAC s/n: 1326-0651-7402-0424-4066-8309
Photoshop CS3 v.10 s/n: 1045-0415-8060-3241-4388-1406
photoshop cs3 extended CS3 s/n: 1045 0415 8060 3241
Photoshop CS3 extended s/n: 1045 0415 8060 3241 4388 1406 or s/n: 1330-1860-4356-5280-6440-7193
Mar 28, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Serial number 1326-1440-8329-8500-5503-7578 authorization code?
try it too
Adobe Creative Suite Design Premium CS3
s/n: 1326-0110-5569-6121-4741-2255 or s/n: 1326-0651-7402-0424-4°66-8309
Jan 03, 2011 | Adobe Creative Suite CS3 Design Premium...
I have a sony viao vgn-ar270. The screen was
This is a known issue with the Video Card in your computer. Hence, Sony will cover the cost of repair (parts and labor) at no charge and, in addition to the standard limited 12 month warranty. Click on the link below to get info on this:
http://esupport.sony.com/US/perl/news-item.pl?mdl=VGNAR270G&news_id=349
You just need to call 1-888-868-7402 and setup service. Your unit will be repaired as well as additional warranty will be covered for your Computer.
Jul 07, 2010 | Sony VAIO VGN-AR270 Notebook
Transistor lost.
if you are replacing 7402
also replace diode 6404 this diode even thou it test goo will in long term overheat 7404 and caus it to go bad by leakage.
and if 7402 gose bad it is regulating the 15v stanby volts that is 7412 is also going to be bad so replace 7412 also
now
the part numbers are:
7402 = # 932211676682
7412 =# 932210514682
thanks,
daniel.
Jan 13, 2009 | Philips 19PR19 19" TV
Computers & Internet Logo
Top NCR Computers & Internet Experts
John Hong
John Hong
Are you a NCR Computer and Internet Expert? Answer questions, earn points and help others
