Question about Samsung ML 2525 BW laser Printer
Chip count over and locked
I have red light on printer controll pannel, its chip counter is over. how to reset samsung ML-2161 laser printer
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
haivanko
  • 37 Answers
SOURCE: how can i do 0 for ml-1640 page count ,and want to resetpagecount
You have to flash the printer with the fixed firmware and it will never ask you again for a new toner cartridge :) it is a 1 minute job for me and i charge my Local customers 10 Euro mostly because it has to be done just once and then you just refill the cartridge without doing anything else ( this is just an explanation - i don't want your money)
Posted on Jun 07, 2010
rh10
  • 122 Answers
SOURCE: The online error light is red on my ML-1610 Mono
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Posted on Jul 16, 2010
Testimonial: "Very helpful!"
SOURCE: Samsung ML 2010 Laser Printer Red light
Posted on Jul 23, 2010
  • 24 Answers
SOURCE: how can I reset chip
I am presuming you want to reset all the systems settings to the factory defaults. Try this:
Clearing memory
You can selectively clear information stored in your machine's memory.
1 Press Menu until Maintenance appears on the top line of the display.
2 Press the scroll button ( or ) until Clear Settings appears and press OK.
3 Press the scroll button ( or ) to select the item you want to clear.
• Paper Setting: Resets all of the Paper Setting options to the factory default.
• Copy Setup: Resets all of the Copy Setup options to the factory default.
• All Settings: Resets all of your settings to the factory default.
• Machine Setup: Resets all of the system settings, such as the display language and save
mode, to the factory default.
4 Press OK to confirm clearing. The selected setting is cleared.
5 Repeat steps 3 through 4 to clear another setting.
6 Press Stop/Clear to return to Standby mode.
Posted on Nov 30, 2010
New Samsung Laser Monorchrome Printer Fuse didn't reset
REPLACE THE NEW TONER CARTRIDGE OR REPLACE THE CARTRIDGE CHIP &FUSE
Feb 16, 2014 | Samsung ML-2510 Laser Printer
Tip
Solution to red light after refill Samsung ML 1540
Samsung printers such as ML 1640,ML 2245 and SCX 4300 have a toner page count embedded in their firmware. This is the reason that once you refill your toner after it has run out,the printer still doesnt print and says toner is exhausted. After you've refilled the cartridge,you'll have to reset the toner count also to zero...to do this,download the firmware here. ML 1640 Ml 2245 and SCX 4300 are not available on Samsung support site. You will need to google it and you may find it in torrents.
run it and it will reset your toner count to 0...you have to do this everytime you refill your toner.
Another solution is to open the backside of ML 1640 and ML 2245,locate the chip 93c66 and short pin numbers 1 and 4 and turn on the printer for a second.It only works in some cases though.
on Sep 01, 2009 | Samsung ML-1640 Monochrome Laser Printer
How to reset samsung1640 laser printer chip
Just short out pins 1 & 4 of the 93c66 chip.
This will reset the counter every time you power up the printer. If you remove the short, the counter
will resume counting but the service date information will not be the same.
Tested using the original initial cartridge.
I think if you want to use a replacement cartridge, you have to disconnect CN5 and short out CN9.
This way the toner will always be treated as the initial cartridge
Dec 22, 2010 | Samsung ML-1640 Monochrome Laser Printer
Hi i am using samsung ml1640 printer after refiling it gives toner exausted messafe what i do to solve the problem
When the number of pages reach the limit specified in the chip it starts to give the message that tonor is exhausted no matter if it has tonor in it or refilled. Replace the chip or tonor and it would work fine.
If its the starter cartridge try following: -
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an introductory one.
Also check out
http://www.savetoners.com/toner-products-a-services/77-free-information-how-to-refill-samsung-ml-1640-1641-1645-2240-2241.html
http://www.arbikas.com/forum/Attachments/ML1640_reset.pdf
Nov 04, 2010 | Samsung ML-1640 Monochrome Laser Printer
Refilled my starter cartridge ML-2240 and put in new reset fuse
Did you change the chip? These cartridge have a chip that tells the printer it has received it's new toner. You can get the chips cheap from a variety of sources online. Just search for samsung 2240 reset chip.
Good Luck
Feb 24, 2010 | Samsung ML-2240 Laser Printer
ML-1640 Series + Toner exhausted.+ how to reset the printer.
Jun 09, 2009 | Samsung ML-1640 Monochrome Laser Printer
I have a samsung ml 2851 nd that won't print, and says the toner cartridge is low - I replaced with cartridge 209 (which office max said would work) and it still flashes the red light and says there is...
The counter needs to be reset most likely. I can\t locate a reset code & steps for you. Try calling samsung and ask about the toner reset you replaced the cartridge and its still showing the count from the old cartridge.
Apr 23, 2009 | Samsung ML-2851ND Laser Printer
ML1640 not working after toner refilling
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Mar 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung ML 2525   BW  laser Printer Logo
65 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
