Question about Dell Inspiron 710m Notebook
Error detected during pre boot system assessment build 3017
Hard drive error detected in DST short test
  • 50 Answers
SOURCE: DELL Latitude D510
unmountable boot volume means that either your system is corrupted, your boot.ini is damaged, or your boot sector is corrupt. Try this:
"You can boot to the XP cd and when you see the Welcome to setup press the letter R
You will get a dos prompt
Then type "chkdsk /p" without the quotes and hit enter
When that is done type "fixboot" and hit enter
"Y" and enter at the prompt
Then type "exit" and hit enter
The system will now reboot into Windows"
Posted on Nov 19, 2007
e-ware
  • 776 Answers
SOURCE: I am getting a dst short test failed error code 1000=0146
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Posted on Sep 10, 2009
Vaio Tech
  • 166 Answers
SOURCE: Dell latitude d610 DST Short Status Test 1000-0146 and 1000-014
try to change out the hard drive on the notebook whid a similar one the size of the hard drive can not be over 160 gb and reinstall windows if it work you may be loss your hard drive
Posted on Oct 10, 2009
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
  • 3940 Answers
SOURCE: Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Posted on Jan 27, 2010
Dst short test fail error code 1000-0146
DST stands for Drive Self Test, if it fails the test it means your drive is failing or has failed. replace hard drive
Jun 02, 2014 | Dell Latitude 100L Notebook
Erorr 2000-0146 in hard vostro 1050
source/original from dell community
Welcome to Dell Community.
Let me first appreciate the fact that you have tried the steps yourself to isolate the problem.
Error code: 2000-0146 (DST Log contains previous errors) refers to previous errors in the hard drive which might not really be a hardware failure. In order to confirm this, I recommend you to run a custom test on the Hard drive which takes longer time than the Pre-boot System Assessment which you have already performed on the computer but it will give the accurate result.
Once the Pre-boot System Assessment is completed, the computer will give you an option to "Run the remaining memory test", please select "No". Then the computer will launch the 32-bit Diagnostics from the utility partition (if available).
After the diagnostics is launched, in the main menu, please click on "Custom Test", then select the "Hard drive" and click on "Run Tests". If the test completes without any error then the hard drive is fine and PC Restore can be performed to restore the computer back to the factory condition (which will result in data loss).
Please refer to the following article for more information on running the Dell 32-bit Diagnostics Utility: http://dell.to/MNJv4B
If you have any further questions feel free to reply.
Nov 28, 2013 | Dell Computers & Internet
I have got intenet address and i tried to write the defaut address of the intenet and ten i shutdown the laptop. but when I tried to start to open the laptop it started to open it had changed to black...
if you have restore cd with you. insert it to your laptop then restart it. it will boot and will try to restore your system. if it doesn't work, you have to reformat your laptop. because your laptop's operating system might just got corrupted. but make sure you have all the necessary cd you need to format your laptop. the drivers, operating sytem (Windows) and other application that comes with the laptop.
Apr 17, 2011 | Dell Latitude D600 Notebook
Dell inspiron wont boot windows..I have ran a pre boot system assessment build 4118... I am getting the error code 0142. msg error code 2000- 0142 please help
That error is normally a bad hard drive. Replacement is fairly easy and not to expensive, but you will have to reinstall a Operating System to the new drive.
Jan 27, 2011 | Dell Computers & Internet
I have a dell studio that says A disc read error when you turn it on , shop told me hard drive gone ,, i am running a pre boot ssytem assesment from pressing f12 and the test say DST short test pass does...
TRY F8 ON BOOT UP TAPP REALLEY FAST IF U CATCH IT INTIME GO TO OPTION LAST KNOWN GOOD CONFIG .....ONCE IT DONE LET IT DO ITS THING IF IT BOOTS LET IT ..THEN ON FULL BOOT LEAVE MIN OR 2 THEN RESTART UR SYSTEM .....SEE IF ANY DIFFRENT
Jan 09, 2011 | Computers & Internet
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Laptop wont turn on
It means that the Hard Disk Drive that holds all your data and the WIndows Operating system is not being seen by the system BIOS. Remove and reseat the hard drive, see if it detects. If it doesn't then you'll be replacing the hard drive.
Nov 14, 2009 | Dell Latitude C640 Notebook
UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Dec 31, 2008 | Dell Latitude D600 Notebook
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
Dell Inspiron 710m Notebook Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
