Question about Whirlpool GH6178XPS Microwave Oven
F-7 My microwave stopped heating. It turns on for a while and then stops with an error message F-7: Call for service.
  • mochammad chodry Mar 18, 2009
    all function running well....during on two noise intermittent.....stopped heating.......what problem?
  • pmvme Apr 21, 2009
    I have the same problem with my GH6178XPS Stainless Steel . My microwave stopped heating and shows F-7 (call for service) in the display. The inverter and magnetron tube have been replaced but a week later stopped heating and the code appeared again. I am waiting for the tech to come back to do another repair. I am a little tired of the mw that has been only used for less than a year.
  • Whirlpool Master
  • 9,173 Answers
There is a mini-manual inside the oven which can aid in troubleshooting.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
F7 BULLETIN
Whirlpool Models GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code appears on the display.
Electrical circuit interruption between L1 and Neutral in the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnetron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves the problem
A. Check the Cooling Fan for proper operation or blockage
B. Check the resistance of the magnetron thermostat. It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W inverter.
8. If problem persists, replace control assembly.
NOTES ON INVERTERS
This model uses an inverter to produce high voltage instead of a convential transformer system.
While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously.
Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan.
Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one.
If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one!
You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Posted on Oct 12, 2007
SOURCE:
Microwave stop working
my microwave oven just stopped heating giving me a f9 error .lights are on clock is working and the panel is ok.
Jun 15, 2010 | GE Profile Spacemaker Over-the-Range...
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
Sharp 930-cs starts fine after 10 or 20 seconds it stops heating, stops spinning & Error message on the display. I replaced the turntable motor but problem continues.
When the Absolute Humidity (AH) sensor is defective (open or short), ERROR will appear in the display after 16 seconds.
If ERROR appears check sensor wire connections and/or AH sensor.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and the Sharp part numbers, most of which interchange except cosmetic parts.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 04, 2009 | Jenn-Air JMC7000 Microwave Oven
Microwave stopped heating
More than likely the magnatron has failed,it is the heating source for microwave and usualy has 5 year warranty so it would be worth calling company about this. They will hve service company repair at no cost to you.
Apr 21, 2009 | Microwave Ovens
Microwave, adora, stopped heating
Hi and welcome to FixYa,
Almost always, on most microwave including GE Adora, no heat with all else working indicates a problem with the magnetron. Since the magnetron produces high RF energy and operates on high voltage, it would be to your advantage to seek the services of a qualified professional.
If on the other hand, the fault of no heat is coupled with no display, error messages, door not locking, no light, then it would be possible for a DIY (do-it-yourself) repair. All that is required is a bit of familiarity with electronic components and circuitry, the use of a DVM/VOM of course safe working practices when repairing electrically powered devices.
Pls post back any other symptoms or indicators other than 'no heat'.
Good luck and thank you for using FixYa.
Mar 14, 2009 | GE Adora DVM1850 Microwave Oven
F-9
Need to know the entire model # on the microwave.
Oct 05, 2007 | Microwave Ovens
F-9 error on LG microwave
This is a problem with the inverter or magnetron. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. You can find support for service or parts at http://us.lge.com/support/support.jsp
Sep 15, 2007 | LG LMVM1945 Microwave Oven
Whirlpool GH6178XPS Microwave Oven Logo
519 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
