Question about RCA S2001 MP3 Player
The player accepts the music download, but will not turn on. A pop up message appeared saying to set the clock before the player would turn on. Cannot get the player to turn on and cannot get the pl
The player accepts the music download, but will not turn on. A message popped up saying the player will not turn on until the clock is set. How do I set the clock? I have tried at the rca website and connecting to the web, but nothing seems to work. How do I set the clock to allow the player to turn on?
SOURCE: Can't Sync Songs
I love my mp3 player but it is soooo boring. i can't add music and i don't have any good songs. Someone please help me before i go off.
Posted on Dec 27, 2007
eclark317
  • 159 Answers
SOURCE: Tried to download RCA EasyRip installer, says file is corrupted.
If the easyRip does not work for you. Try this download media coder. http://mediacoder.sourceforge.net/index.htm 0.6.1.4.8 works for me. After you install it. Goto Extensions click it. Home players. Then mpeg maker. It will ask you to remember my choice . Click yes. And enter these settings.
Mpeg-2 2.5 mbps (svcd) 25 fps 352X288 mpeg audio 224 kbps original 1 stream
Bitrate 194.
this setting also works. Mpeg-1 2.5 mbps (svcd) 25 fps 352x288 mpeg audio 224 kbps original 1 stream Bitrate 194 ... once converted can drag and drop into opal and video will play. Its says its and mped but on opal shows up as an smf file. Works great and the video is better than the rca easyrip converstion tool. Hope this helps you alot
Posted on Jan 02, 2009
SOURCE: my rca pearl mp3 player modle # is TH1100A
my pearl was drop in the water but it still works and when i plug it on to the computer i cany put any more songs on it
Posted on Jul 23, 2009
  • 19 Answers
SOURCE: cant put musci on my RCA Pearl 512 MB Digital Audio Player - TH11
You need to connect up USB cable and then go to Windows Media Player program and WMP will guide you on how to download music
Posted on Sep 14, 2009
  • 5 Answers
SOURCE: rca easy rip
My RCA easyRip is not turning on i tried everything... i gave it to my dad and he coulnt solve the problem... i put water on it accidentally is that the problem??
Posted on Sep 12, 2010
I have a message on my sansa clip that I want to get rid of so that I can continue to listen to my book. I can't listen till this is straightened out. It says synchronize to continue your music...
Audible books are protected, you can copy them into device, but you can't play them (...subscription...appearing ). You must use audible manager to sync audible books.
You should delete audible books that make pop up a message " synchronize to....", otherwise, your device always pops up the message when it meet the audible books.
Apr 06, 2010 | SanDisk Sansa Clip MP3 Player
Suddenly my player can't transfer music files(mp3) (using windows media player). a message pops out saying that an unknown error occured/ player disconnected. im not even touching it while it's connected!...
Hi ! it´s a better idea to transfer you music using the explorer make a folder with your favorite music and then copy to the device if your device appears as a mass storage device.... ;)
Hope it helped
Jun 24, 2009 | Audio Players & Recorders
This thing does not work always says ok to disconnect
When the mp3 player is connected to the computer, the only message it will generally give you is "OK to Disconnect" - this is normal.
Once you disconnect the mp3 player from the computer, then you can find your music, listen to music, etc.
If you are getting the "OK to Disconnect" message when the mp3 player is already disconnected from the computer:
Reset the player first.
If that fails:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Feb 28, 2009 | Philips SA3025/37 Flash MP3 Player
Nokia n95 music player problem
try pluging your walk and talk speakers in and out.. otherwise try a factory default under settings
Dec 05, 2008 | Nokia N95 Cellular Phone
Synchronize to continue your music subscription
I ran into the same problem with my Sansa when listening to legally downloaded audio books from the local library. This is what I found:
  • " Are you sure the player is in MTP(plays for sure) mode when you transfer it? You can check by going to settings>usb mode on the player itself. I think it needs to be for you to use library files like that. " (This worked for me)
  • "are you copy and pasting the files? if so you will need to use WMP to sync the files. copy and paste might not be transferring the license." (didn't try this -- didn't need to)
Hope this helps.
Nov 26, 2008 | Audio Players & Recorders
Setting clock
Try the following:
1. Turn the AudioStation OFF
2. Press and hold both ‘source’ and ‘select’ until the F/W rev appears. The F/W info will display for about 2 seconds
3. Select Menu language
4. Use Up/Down buttons display the language, then press ‘select’ to accept.
5. Press the Up/Down arrows to select 12 or 24 hours format, press 'Select' to accept.
6. Press the Up/Down arrows to change the Hour, press 'Select' to accept.
7. Press the Up/Down arrows to change the Minute, press 'Select' to accept.
Nov 02, 2008 | Logitech AudioStation High-PerDocking...
Clock
CLOCK SETTING
1)TURN CAR IGINITION "ON"
2)TURN STEREO "OFF"
3)PRESS "AUDIO" AND HOLD TILL CLOCK APPEARS IN DISPLAY
4)SET CLOCK BY PRESSING UP,DOWN & LEFT, RIGHT KEYS SITUATED NEAR SRC/AUDIO SWITCH.
5)TURN THE STEREO "OFF" AND "ON" AGAIN TO SAVE THE CLOCK SETTINGS .
6)SELECT THE "CLK " SWITCH TO ALWAYS DISPLAY CLOCK WHENEVER U ARE NOT LISTENING TO MUSIC.
Oct 23, 2008 | Pioneer DEH-2800MP CD Player
I can't find the music on my go gear, yet when I try to re-download the music my windows media center says that the music is already on the device.
The songs are in the wrong format - it will accept some WMA files but not others - Windows Media Player will appear to load them but they will not actually show up on the GoGear. Convert them to Mp3, and they will load fine.
Jun 22, 2008 | Philips Audio Players & Recorders
it's asking that you verify the DRM status (i.e., that you bought it and it resides on YOUR computer.) It cannot play the file until you synchronize it with windows media player. You can delete them off of the MP3 player just by noting which songs don't play and deleting them through windows explorer when the player is connected.
Mar 25, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Error Message
You have to synchronize your Sansa to a computer that has a current subscription to Rhapsody, and you have to sync the Sansa to that same computer at least once every 30 days, or the Rhapsody songs will stop working. Use a different music service that is free, or convert all of the songs to Mp3 format to get around the problem. If you get a subscription to another music svc, then you must maintain a current subscription with whatever new svc you choose as well.
Dec 27, 2007 | SanDisk Sansa e260 MP3 Player
RCA S2001 MP3 Player Logo
24 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
