Question about Texas Instruments TI-83 Plus Calculator
Log 10 key - Texas Instruments TI-83 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
The key just to the left of the "7" key, marked "LOG"
Posted on Jun 08, 2014
How do i do square root on texas instrument ti-15
hi
if it a scientific calculator there should be a surd key ( look like a square root symbol, other way to get a square look for the "^" key that the exponent or power key do the follow type in the number be square rooted and press the "^" key and type "(1/2)" ( without the "" of course) and you will get the square root of your number. You can use the log and ln keys as well
type in your number you want square rooted and press the log or ln keys divide the result by 2 press the anti log key use might have press the 2nd key or shift key and press the log ( or 10^ key) or ln( or e^ key) the 10^ key and the e^ key change log to normal numbers
i.e.
square root 9
type 9 press log to get .954242509 for a result
divide by 2 to get .477121255 press the 10^ key to get
3 for a answer.
Aug 12, 2014 | Texas Instruments TI-15 Calculator
Anti log casio fx 85 es
The inverse of the log function is the function 10^
y=log(x) has the function x=10^y as inverse.
y=ln(x) has the function x=e^y
log and 10^ have the same key.
ln and e^ have the same key.
Jul 15, 2014 | Office Equipment & Supplies
Log 3 base 10
Press LOG 3 ENTER.
The LOG key on the keyboard gives you base-10 (common) logs while the LN key gives you base-e (natural) logs. If you want the log to another base you can use the logBASE function found in the catalog.
Apr 07, 2014 | Texas Instruments TI-84 Plus Calculator
How do I work the anti log on TI-30X 2s? Where are the buttons?
What you call the antilog is also known as as the power function. More specifically, the inverse of a decimal log is the function 10 to a power, (10^x) It shares the same physical key as the log function. If the calculator has a key marked [LOG] you have to press the [2nd or SHIFT] key followed by the [LOG] key to activate the anti-log.
For natural log (logarithms in base e) the antilog is the exponential function (e^x). It shares the same physical key as the [LN] function.
May 09, 2011 | Texas Instruments TI-30XA Calculator
I need to punch in: -log 10 Ka to get pKa,how do i do that? let's say Ka = 1.75 X 10^-5 the answer = 4.76 pKa = -log 10 Ka show me step by step how to punch in. thanks!
(-) LOG 1 . 7 5 EE (-) 5 ENTER
The (-) is just to the right of the decimal point, the LOG key is in the leftmost column between the GRAPH and LN keys, the EE key is just above the 7 key.
Dec 11, 2010 | Texas Instruments TI-85 Calculator
How do i enter pH on a TI 30 calculator
This post answers two questions
  1. How to obtain the concentration knowing the pH?
  2. How to obtain the pH knowing the concentration
If you are not interested in the theory, jump to the examples at the end of the post.
As you well know the pH is the negative of the log in base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since raising 10 to a power is the inverse function of taking the log in base 10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Examples
1. Let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Calculating the pH
Shortcut:
For all H+/H3O+ concentrations of the form 1.*10^(a) where a is an integer number between 0 and -14, the pH is the negative value of the exponent.
Concentration =10^(-3), pH=3
Concentration=10^(-11), pH=11
For other concentrations such as 3.567*10^(-8), one cannot use the shortcut above, but have to calculate the log of the concentration
[H+/H3O+] = 3.567*10^(-8)
pH= - log(3.567*10^(-8))
This is keyed in as follows (to minimize the number of parentheses)
8 (-) [2nd][10 to x] [*] 3.567 [LOG] [=] (-)
Here you have two (-) change sign, the first is entered after the exponent of 10, the other at the end of the calculation to take the negative of the displayed result. You may notice that it is entered in the reverse order of the defining relation - log(3.567*10^(-8)).
To verify your calculation, the result is 7.447696891 or just 7.45
If you have a problem with the first (-) try entering it before you type in 8.
Hope it helps and thank you for using FixYa
And please, show your appreciation by rating the solution.
Dec 07, 2009 | Texas Instruments TI-30XA Calculator
How to use antilog?
[H+]=10^(-pH)
Exemple: let the pH=5.5, what is the H+ concentration?
Hope it helps.
I am trying to find out where is
Please read the following with patience.
  1. Let y=10^(x) ( 10 raised to the power of x)
  2. Take the log of both tems of the equality.
  3. You getlog(y)=log[10^(x)] where I used square brackets for clarity.
  4. But from the general properties of logarithmslog(b^(a)) = a*log(b)
  5. Applied to our expression above ( in Number 1)log(10^x)=x*log10
  6. But since we are using log as log in base 10, log_10(10)=1 so log(y)=x
  7. We thus have two equivalent relations y=10^x <----> x=log(y) The double arrow stands for equivalence.
If y is the log of x, then x is the antilog of y
Let's get back to you problem : To obtain the antilog you use the key marked with a 10^x.
Exemple1: What is the antilog of 3
Answer: Antilog(3) =10^3 =1000 because log(1000) =3.
Exemple 2: What is the antilog of 1.543765?
Antilog(1.543765) = 10^ (1.543765)= 34.97558603
Exemple3: What is the antilog of -0.37654?
Answer: Antilog (-0.37654) =10^(-0.37654) =0.4202038237
Look on the body of the calculator if there is key or a [Shift] key labeled with 10^x ( a 10 with a small raised x). If you are able to find it, use it. If not, you can always use the [raise to the power key] ( a caret ^, or Y to the x or X to the y.) For the last exemple, you type it as follows.
10 [^] (-) 0.37654 [=/ENTER]. The (-) is the change sign not the regular Minus.
Hope it helps.
Thanks for using FixYa.
Nov 19, 2009 | Sharp EL-531VB Calculator
I am asked to find the log of 6.02 X 10 to the 23rd power> How can I find 10 to the 23rd power?
Why complicate matters for yourself?
You were asked to calculate log(6.02x10^23), let your finger do the calculating.
I checked the claculator manual and you have to enter it all at one go. Pay attention to the key strokes. You will not do it in such a laborious manner
23[10^x] [=] gives 10^23
23[10^x]*6.02 [=] multiplies 6.02 by 10^23 to give you Avogadro s number.
To find its logarithm in base 10, you have to enter the number then press [LOG] . When you press [LOG] you are calculating the log of the last result. You obtain 23.77959649.
If I had given you the key strokes directly you might have not understood why I do things this way. Now the actual key strokes you enter
23[10^x] * 6.02 [LOG] [=]
If you are only looking for your result, you are done. You can ignore what follows.
If you know the rules for the logarithms, you can do the calculation more easily. log here is log in base 10
Rule 1 Log(a*b)= log(a) + log(b)
Rule 2 Log(c^n) = n* log(c)
Rule 3 log(10)=1
Thus applying the rules
log(6.02*10^23) = log(6.02) + log(10^23) first rule applied
= log(6.02) + 23*log(10) 2nd rule applied
= log(6.02) + 23 3rd rule applied
= 0.77959649 + 23= 23.77959649
Hope it helps
Oct 10, 2009 | Texas Instruments TI-30XA Calculator
How can I use the Log function on my calculator?
Hi ;
for log base 10 use the the "log" key
example :
log(2) + log(3) = log(6)
enter 2 press the log key you will get 0.30102999 press the '+" key than 3 log you should get 0.47712125 for it Press the "=" or enter and you should get 0.778151250 for a answer than press inv or 2nd log and you should get 6 for a answer
and that all there is to it
Oct 07, 2009 | Texas Instruments BA-II Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
13 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
