Question about Polaroid Tablets & eReaders
Unlock model: PMID4311 FCC ID:FCV1207092C - Polaroid Tablets & eReaders
My iPad was "reset all setting" and now it only display an usb cable and draws an arrow to the word itunes. It is iPad 16 GB Model A1396, FCC ID: BCGA 1396 and IC: 597C-A1396 How to return it normal?
It is telling you to connect it to your PC or laptop where you have iTunes installed. If you don't already have iTunes installed in your computer, you will need to download and install the iTunes software to it. When your iPad is connected, iTunes will synch and update it if you managed to erase the O/S or other necessary items. iTunes connected via the USB cable is even able to install or update the tablet's operating system. It's not just for music.
Your laptop or desktop will need to be connected to the Internet in order to download updated or original operating system. Just follow the prompts.
Apr 08, 2015 | Tablets & eReaders
Problems with Azpen A727 tablet.
Soft Reset Press the reset button on the back of the tablet with a fine point object for about two seconds. This will not erase data store on the tablet. This may help if the screen is frozen or not responsive to touch.
Nov 24, 2014 | Tablets & eReaders
FCC ID: IHDT56MT1
try e spares on the internet
Jul 15, 2014 | Motorola Tablets & eReaders
PMID4311 touch pad replacement
where can find 4.3 lcd sreen w ribbon now
Jan 02, 2013 | Polaroid 4.3" Internet Tablet
Need to unlock my craig 741e tablet
I got a Craig 741e (CMP741e), FCC ID AQF-RA-WN11087A with a lost password, stuck on a lock screen, forgotten pattern, no wifi connectivity.
The Craig does NOT support a reset mode, none of the typical combinations of power/volume buttons get you to a restore screen.
The only supported way to restore to default is a firmware restore mode.http://www.craigelectronics.com/site/pdetails.php?id=414 will tell you how to get the firmware file
http://www.craigelectronics.com/firm...irmware4.0.rar
(install instructions: http://www.craigelectronics.com/firm...guide_741e.doc)
HOWEVER! Some CMP741 units will end up stuck on the green Android screen with this version!
If that happens, Craig has supplied a cleaner firmware in case that the first one fails,
http://www.craigelectronics.com/firm....0_cleaner.rar
The name of the core image in that RAR file is sun4i_crane_aihua_20121121, if that gives anyone clues about the system.
Installs the same way - will reboot several times after the firmware install completes, and will fail the first time it runs ("Unfortunately, <process name> has stopped." over and over again). One more reboot will solve that issue.
The Flashing software, PhoenixCard 3.06, is VERY buggy. If would not work with my built multi-card reader on my PC or with an add on-SD card reader on that PC. (could not even see the card). On my laptop, the built in PCI Card reader never recognized the card, but it finally burned the card using the add on card reader. Some people suggest disconnecting ALL USB peripherals before burning. Also, I found if the flash burning failed over and over, sometime a reboot caused PhoenixCard to start working again.
Dec 31, 2012 | Tablets & eReaders
Forgot my passcode
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 12, 2012 | Amazon Kindle 3G
Tablets & eReaders Logo
Top Polaroid Tablets & eReaders Experts
John mullen
WTF Chuck.....
WTF Chuck.....
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
