Question about Samsung Washing Machines
What will I do if my samsung wahsing machine has AE6 ERROR
What dose it mean AE6 error code in Samsung wash machine
SAMSUNG WASHER FAULT CODES: AE or AE6
SAMSUNG WASHER ERROR DEFINITION = communication errors sub and main PBAs - main and inverter PBAs
AE and AE6 represent communication errors between the sub and main PBAs or the main and inverter PBAs.
HOW TO REPAIR/CLEAR ERROR?: If either of these errors is displayed, troubleshooting is needed or service is required.
http://removeandreplace.com/2016/06/15/samsung-washer-quick-troubleshooting-guide-error-code-definitions/
Feb 17, 2017 | Samsung Washing Machines
Flash code A E 6
google make .model and error code see what you find .
May 16, 2015 | Washing Machines
How do you replace the water inlet valve on the estate by whirlpool
You unplug the machine, turn off water and bleed off pressure, open the wahsing machine case, disconnect water hoses and electrical connections to the valve, and then unscrew the valve's mounting screws.
Oct 03, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Wahsing machine is flashing 11 F what does that mean?
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
No power going to the wahsing machine
CHECK THE SWITCH BOARD WITH TESTER IF SUPPLY IS COMING IF IT COMES THEN CHECK IF THE POWER CORD IS ALRIGHT THEN OPEN THE MACHINE AND CHECK IT INSIDE
Jun 10, 2009 | Fisher Washing Machines
Bosch Excel 1200 wahsing machine, when trying to activate spin, it shows the normal 10 minutes, but then goes straight from 8 mins to 1 min and items arent properly spun
bosch exxel 1200 washng machine
has error message 04 and wont drain or spin
what does this mean?
can you help?
have lost instruction book
Mar 27, 2008 | Washing Machines
Washing Machines Logo
391 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
