Question about Unknown Office Equipment & Supplies
Canon lbt2900 After reinstalling setup of lbt2900 canon its still not giving a print of any prongrams . So i wanted to know what is solution fot that .
WHY I CANT INSTALL CANON LBP6000 IN MY PC WIN 7 BIT 64
You may want to download the Canon Driver Installer first to help download the print driver. I checked the latest list that Canon is offering, I see the LBP5000 but nothing for the LBP6000. I have used a previous model's driver for other manufactures, I don't see why the 5000 driver wouldn't give you most, but not all the features the 6000 offers. You also may want to see if Canon offers a firmware upgrade which would make it compatible with Windows 8.1
Jun 27, 2014 | Canon LBP6000 Laser Printer
Not printing all info
try a test page first, please, and let us know the results.
May 10, 2008 | Canon PIXMA iP90 InkJet Printer
My printer isn't producing any ink?
The manual says:
Follow the directions given in the Easy Setup Instructions to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it.
If the error is not resolved, the Print Head may be damaged. Contact your Canon Service representative.
take care putting the head in as discribed in the setup description.
I'll think it over if there could me more
Oct 27, 2013 | Canon PIXMA MP810 All-In-One InkJet...
Can't print photos with correct colours. Photos in .jpg format and I know colours on screen match colours when printed commercially. Printing from Zoom Browser or Canon Easy Photo gives much worse results...
First clean the print head and run the test print and then the alignment setup to make sure that the printer is clean and registers correctly. In the Printer Properties (Right click on the printer name via Control Panel - Printers) there is an option tab for Colour Management. Click this and select the source that you need to match the print output to. Also go through all the other tabs in Pinter - Properties as there are many setup options there to setup and tweak the colour balance and adding effects etc. This can be quite a lengthy process but well worth the effort. There is no shortcut to doing this but you will end up with a precisely calibrated custom printer setup that you can save and reuse at any time. I have these profiles defined for my printers for each media type and each ink supplier although I have minimised the number of profiles by now using 1 bulk ink supplier to get consistency between cartridge changes and CISS refills. Note that this may vary when you change print carts or change the media type and manufacturers.
Oct 07, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Change language Japanese to English Canon MP600 printer
when ur give the order of printing. it shows various options related to ur print on screen such as font style,paper type ...
in those u can find ur language setting.Just change it toENGLISH.
if it doesnt work then reinstall the printer setup & that time choose the ENGLISH language.
Jul 05, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Mar 10, 2009 | Canon Office Equipment & Supplies
How to configure IP address on Canon IR400 Printer Please give me step by step details for setting up printer.
RESTART THE MACHINE AND PRESS PRINT BUTTON ON THE TOP OF THE PANNEL AND IT WILL SHOW WAIT... AFTER THAT A SCREEN APPEARE LIKE (DO U WANT TO ENTER SETUP AND OPTION APPEARS YES / NO PRESS YES IMMEDEATELY) THEN U SELECT NETWORK SETUP AND TCP/IP SETUO
Jan 23, 2009 | Canon imageRUNNER 400S Copier
I have a canon pixma mp 610 that prints okay excpet for Quicken full page checks. It prints only part of one check, not all three. Please help.
Few possibilities...
Incorrect settings in properties of printer. Software glitch, Please reinstall driver. Unplug printer for couple of minutes from AC outlet and replug back in and try.
Jan 10, 2009 | Office Equipment & Supplies
Printing on a 3x5 card
sounds to me its software issue, the best way to do this is to go into your printer properties and check to see if it has selected 3x5 for print not 8 1/2 x 11
my wife has that problem all the time when shes trying to print pictures of the kids and ushally its due to not being setup on the printers properties you can also set it up from right here
if you go to file on the top menu here and then goto print from here we will be able to select the printer and goto the options on it and make sure the page is set for 3x5 make sure your printer is highlighted and then click on preferances and then look in there. I dont have a printer hooked upto my laptop right now so I cant give you any further steps but I know its in there.
let me know how you make out if I have to put a computer onto my laptop and give you more detail on this then I will
Oct 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Will not print black
first of all the most important auestion is have you used compatible ink cartridges or genuine ones, because the print head clogs up with compatible ones, i really doubt that the cartridge you installed is damaged because i haven't come across this and i am a canon technician, i know this model well
Nov 02, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
26 people viewed this question
Top Unknown Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Unknown Office Equipment and Supply Expert? Answer questions, earn points and help others
