Question about Acer Aspire One AOD270-26Dkk 10.1" LED Netbook - Intel Atom N2600 1.60
Hi i have aspire one d270,PCI DEVICE is not working..what should i do?please help me my net book cannot read any flash drive/external drive using USB.
mdsaeed67
  • 849 Answers
SOURCE: acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
Posted on Nov 25, 2008
SOURCE: PCI DRIVER
GO TO ACER SUPPORT AND DOWNLOAD AND INSTALL... ENE Card Reader Driver 3.00.00 THIS WILL FIX YOUR PROBLEM
Posted on Feb 10, 2010
  • 117 Answers
SOURCE: My acer aspire one netbook has a retacktable mouse
if this is a wireless mouse then the usb connecter and the mouse both need to be synched up to each other. there is usually a small button on them both.
Posted on Jul 06, 2010
  • 107 Answers
SOURCE: Acer Aspire 4730Z Win7 can detect USB port but
Try to reinstall / update Intel chipset driver to your laptop.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Posted on Jun 28, 2011
  • 4961 Answers
SOURCE: Acer one d270 pci bus 3 error in device manager
You need to reinstall your chipset driver for your computer... You can get it here:
http://global-download.acer.com/GDFiles/Driver/Chipset/Chipset_Intel_9.2.2.1034_W7x86_A.zip?acerid=634624618277356176&Step1=Netbook&Step2=Aspire%20One&Step3=AOD270&OS=722&LC=en&BC=Acer&SC=PA_6
Posted on Jul 16, 2012
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
Hi im trying to install windows 7 on my aspire 4715z, as im starting to start the instalation when an error appear "a required cd/dvd drive device is missing. if you have a driver floppy disk, cd,...
Hi there !
Your windows operating dvd installer is damage. It just the CD/DVDROM drive cannot read your DVD installer because it have too many scatches in your DVD. Just get new OS dvd installer and repair your windows 7 operating system or reinstall the operating system.
Jan 26, 2011 | Computers & Internet
Usb pulled out during use now not working
Sometimes when a flash memory stick or USB hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory or USB external hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 27, 2009 | Western Digital My Book (WDG1U2500)...
WHEN I TRY TO PLUG IN A HARD DRIVE OR A PRINTER INTO ANY USB SOCKET I GET A MESSAGE SAYING USB DEVICE NOT RECOGNISED BUT IT WILL PICK UP A FLASH DRIVE PLEASE HELP
Is it an external/portable hard drive? Use the rear USB panel, if problems persist, try using your hard drive on another PC. And if you're still having problems, try replacing the USB cables of both the hard drive and printer. If it works on another PC/laptop, buy a PCI USB panel, and install it on the PCI slot of the motherboard. Hope This will help you.
Sep 24, 2009 | Computers & Internet
External hard drive not being read by media player
did you find an answer to your question? I am currently having the same problem. The USB LED flashes and takes a minute to scan, followed by a pop up on the tv saying unable to recognize hard drive. help?
May 14, 2009 | Western Digital My Book Premium ES...
Sony microvault 2 gb
my laptop does not read the usb stick, when i insert it, a pop up says usb device not recognized, and has malfunctioned. I am having this problem after using this usb device in a car stereo system. please advise i need to recover my data from the device. please help me in this issue.
Apr 10, 2008 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Computer freeze on saving files to USB 2.0 External Hard Drive (and USB2 flash drive)
Suggest you look at the motherboard book to check if or how many USB connections are in fact USB 2 compatible. Most modern Motherboards only have 2 USB 2.0 Compatible connections, most are 3.0 or 4.0 compatible. Hope this helps, Malcolm Campbell.
Mar 12, 2017 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
Acer Aspire One AOD270-26Dkk 10.1" LED Netbook - Intel Atom N2600 1.60 Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
