Cdc40 dab reset - Audio Players & Recorders
How do I set the fm volume to be the same as dab?
This depends on the Music System. Check the manual, check in settings and see if there is volume normalizer or try keeping the eualizer in defult, or reset the system.
Oct 04, 2014 | Car Audio & Video
I HAVE A SC-HC30DB SYSTEM AND IT'S NOT LETTING ME IN THE DAB MENU,DAB NOT WORKING ALL WORKING OK OTHERWISE.
I had the same problem - you can fix with a system reset. Unplug the unit at the wall and wait 2-3 mins, then plug in and switch on while holding the power button - the display will be blank for at first, but will eventually display '---------------------'. Release the power button and switch the unit on as normal. Press the Dab button and the unit will start to auto-search for channels. Give it a few minutes and you'll be back in action :)
Chris
Jun 29, 2011 | Panasonic SC-HC30 Audio Shelf System
The DAB on my CR-515 has stopped working and says 'no stations'. What's hapened?
Just had the same problem. Had a power cut in the area and it's wiped everything on my CR515. You need to reset it to the factory defaults.
On the actual stereo (not remote), switch it on, then hold the stop button followed by the on/off button. Clear will appear on the screen and it'll then turn itself off, When you turn it back on, it'll ask you to wait. Your DAB should be restored.
Bear in mind, this will reset all your presets and any other preferences you have set on your system. It should also, however, restore your DAB.
Mar 19, 2011 | Onkyo Audio Players & Recorders
I have a proline DAB 100 alarm clock radio, I went
I am finding difficulty to set the clock on Proline dab 100 fm
Jan 03, 2010 | Audio Players & Recorders
Need manual for Alba Clock Radio CRDAB301
Sorry m_gerard, I can't help you with the manual.
However here is a partial list of operations for the Abla CRDAB301:
Switch on
  • Press STANDBY
Switch off
  • Press STANDBY
Factory Reset:
  • Switch the radio on;
  • Press and hold MENU for 2 seconds
  • Press SELECT.
Switch between FM and DAB:
  • (radio must be on)
  • Press DAB/FM
Tune & store all DAB stations:
  • Press MENU
  • Press ">" three times (or until display says "Autoscan full")
  • Press SELECT
To listen to another DAB station:
  • Press "<" or ">" until the station name is displayed
  • Press SELECT
Hope that helps!
Apr 20, 2009 | Audio Players & Recorders
Deleting memory on Mikomi DRF350x Dab radio
To perform a system reset on a Mikomi DRF350X:
1) Turn on
2) Switch to FM using the 'DAB/FM' button
3) Disconnect power (e.g. unplug the PSU from the mains)
4) Push and hold 'Enter' whilst reconnecting the power
Mar 12, 2009 | Electronics - Others
Setting the reset stations on a DAB radio
I used lateral thinking! looked at the instructions for my other matsui DAB radio and worked it out from there. With this Ferguson model you have to find the station you want manually and then press one of the preset buttons (it only has 4 but these are enough for me)
Jan 06, 2009 | Audio Players & Recorders
How do i reset a HITACHI AX-M131U DAB/FM/CD/USB/MP3 MICRO HI-FI SYSTEM i want to retune it
push the funtion button till dab bomes up on the screen then push in the info button and it will start to retune dab. for a total reset just push the select button 1 second after you hold the info button for 5 seconds
Mar 09, 2008 | Audio Players & Recorders
How to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Feb 29, 2008 | Audio Players & Recorders
22 people viewed this question
 Grubhead
Grubhead
