Question about Sewing Machines
Installing a bobbin on Brother VX-847 - Sewing Machines
Mimito7
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
  • 1116 Answers
SOURCE: Brother VX 1250. The
Check the needle to be sure it is installed with the flat side facing the back of the machine.
Check the needle to be sure it is not bent.
Posted on Mar 02, 2010
  • 1116 Answers
SOURCE: Brother VX 1100 will not pick up bobbin
Replace the new needle, making sure the flat side is to the back of the machine.
Hold on to the top thread as the needle lowers and raises.
If it does not catch the bobbin thread, the timing may need adjusted.
You can find a graphic for adjusting the timing at sewusa.com, or take the machine in for service.
Posted on Mar 10, 2010
SOURCE: Brother VX 1120 sewing machine bobbin holder missing
you can buy one from this website.
http://www.sewingpartsonline.com/bobbin-case-class-15-japan-made-jo1313z-j.aspx
Posted on May 20, 2010
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Posted on Oct 30, 2010
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
Brother 1100, was sewing , now it is froze, cant turn the wheel far either way, cleaned, wants to go but is stuck, I cant see any thread in bobbin plate but I think that is where issue is advise
You could check the bobbin winder shaft. If this is engaged the machine appears to have frozen while turned on. Move the bobbin winder shaft left, then right while checking the foot controller and you will soon know if this is the problem.
Nov 08, 2016 | Brother Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
How to thread the bobbin on a brother vx 1500
Did you ever find out the answer? i just got one of these models with no instructions and im so lost!
Aug 16, 2012 | Brother Sewing Machines
I can not get bobbin in brother model #vx-1140 to work or even rotate
could the bobbin be bent or warped?
could there be something wrong with the bobbin case?
Apr 16, 2012 | Brother Sewing Machines
Need a free brother vx-847 manual
Go to the Brother website
Go to support--click on it
Look toward the bottom--for manuals & documention
Select product group--home sewing
Select model
if you don't see your model contact brother customer service
Feb 11, 2012 | Sewing Machines
Jan 27, 2010 | Sewing Machines
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
