Question about Exercise & Fitness
Nordictrack asr 1000 keeps beeping
As soon as I power up my Nordictrack ASR 1000 (plug it into the wall) the monitor starts beeping at random intervals. The problem has gotten so bad that no one in the house will use it because it beeps so much.
  • Chris Gerlt
    Chris Gerlt Jun 17, 2015
    I had the same problem. I took the four screws out of the back of the plastic electrical unit. Opened it up, and snipped the wires that connect to the speakers. Perfect, no more audio, period. I consider that solved.
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
Posted on Jun 11, 2012
ercupa190
  • 12223 Answers
SOURCE: Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Posted on Nov 19, 2012
Nordictrack elliptical asr 700
Hi There,
There may be a problem with a power wire inside the machine.
Ring Icon Fitness to repair.
Aug 24, 2014 | Exercise & Fitness
Display lights up but no information displayed
did you change the batteries or are you using a power cord?
Mar 25, 2014 | Nordic Track Nordictrack Ack Asr 630...
NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
Nov 27, 2012 | Nordic Track Nordictrack Asr 630...
Console 1
Nov 18, 2012 | Nordic Track Nordictrack Ack Asr 630...
Skips when running on nordictrack 1000
Run the software calibration for diaignostic, troubleshooting, and fix it.
However you see the video and adjust it.
Sep 24, 2012 | Nordic Track Nordictrack Asr 1000 cwl...
God bless you
Jun 10, 2012 | Exercise & Fitness
What is asr button
Anti Slip Regulator (ASR button) stops power to the wheels when they spin (on slippery surfaces ),the ASR is designed to be turned off only when you require the wheels to spin at low speed,EG: when you are on snow or ice,as the ASR will stop the power to the wheels if they start spinning,you would never get anywhere. over 20 M P H is not active and serves no function.......hope this helps......cheers.
Aug 18, 2011 | 2000 Volkswagen Jetta TDI
It seems a belt has slipped off nordic track asr 700. How do I remove cover to get a better look?
You have to pull the upper console and console tower before removing the panels, If you have access to a owners manual I suggest looking at the explodes parts it will give an idea of disassembling the unit. If you need a manual the go to iconservice.com click on manual input this info NORDICTRACK ASR 700 ELLIPTICAL (NTEL00607)
May 21, 2010 | Exercise & Fitness
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
May 17, 2010 | Nordic Track NordicTrack Elite zi...
Exercise & Fitness Logo
197 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
