Question about Samsung DV520AG 7.5 cu. ft. Gas Steam Dryer
DV520AG AXX click but drum will not start
In the display it shows that the cycle is going normal, I hear a click but the drum will not move
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Good Afternoon Modle DV219AG Gas Dryer: The
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 21, 2011
Main motor won't turn when in spinning cycle
Door switch is defective. Find the plastic piece on door and then find the switch in the machine. Ouch the switch in with a pencil. If you do not hear a clicking sound the switch is bad. Stops the machine from spinning. Easy to change
Mar 29, 2016 | Washing Machines
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
Hi, I have an Amana front load washer NFW7200TW that will go through entire cycle but won't spin- cycle ends and clothes are very wet. Unlike the other posts I read, mine shows no error code nor does the...
I have a similar problem with a Kenmore top loader washing machine.It turned out a problem with the main shaft of the drum; it wears out and caused drag on it. at one point i installed a washer or spacer between the shaft and drum it worked for a while and the problem came back again. it is a mechanical problem and it is present with other brands that share the same drum and shaft.
Finally I end up buying a different brand this time a LG .
Mar 08, 2015 | Amana Washing Machines
Have a UC code. Washer starts than stops during cycles when the drum is moving. also hear a clicking sound Tx, Bob
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 600 Series Gas Dryer, about 2 years old. Makes a loud scraping or rumbling sound as drum turns, not constant but in a cycle, as if off balance. I checked to be sure it is level. What are the likely...
It is normal for the dryer to make sound due to the high velocity of air moving through the dryer drum and exhaust system.
A clicking noise may be the timer advancing.
Check the load for objects such as coins, nails, etc. Remove promptly from dryer.
It is normal to hear the dryer gas valve or heating element cycle on and off during the drying cycle.
The dryer should be level and installed on a solid floor.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 16, 2010 | Kenmore 63942 Dryer
Dryer making a rumbling sound when running
Jun 16, 2010 | Maytag MED9600S Electric Dryer
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Clothes remain dripping wet after the wash cycle is complete.
I assume you have removed the lint filter at the bottom of the machine and cleaned it out to make sure the pump is not stalled on a 1 pence or bra clip. Can you hear the motor start to spin? If not its probably because the water level switch is gunged up at the bottom of its rubber tube where it comes from the drum. Remove the top of the machine and locate the pressure switch - usually a round black or white device about 80 to 100mm across with a rubber pipe on a small spout 8mm diameter. Take the pipe clip off using pliers to compress it and move it back down the pipe. Remove the pipe and blow hard down the pipe to try and clear the blockage - you will hear bubbles blowing in the bottom of the drum water. Also you could very very gently blow into the switch stub pipe and listen for it changing over - clicks usually twice each way - blow - two clicks, release - two clicks. Restore swtch pipe and try the machine again. Good luck.
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dirty water runs back into washer, moving drum, you hear it.
What kind of washer. Most washers will have a balance ring in them. This balance ring has liquid sealed inside it. So you will hear water swishing when you move it.Totally normal. If water is indeed running back into the tub, you need to pull your discharge out of the wall. It should only go in about 2 ft max. Any deeper and you can get syphoning. Dave www.washermd.com
Jan 13, 2009 | Washing Machines
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Samsung DV520AG 7.5 cu. ft. Gas Steam Dryer Logo
53 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
