Font Capture AcroRd32.exe - Bad Image error
Can't open any pdf files.
  • 2,113 Answers
C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\AcroRd32.exe
That one? or another version?
Posted on Nov 24, 2013
  • mikadot
    mikadot Nov 24, 2013
    https://skydrive.live.com/?cid=b2a94b30c... I put it on my skydrive on the cloud for you
  • Atoo Goo Dec 02, 2013
    Umm mikadot... thanks for the help. what is it you put on your skydrive? I have tried reinstalling, install acrobat reader..... nothing helps. I even tried Adobe reader XI. Any help?
3 Suggested Answers
SOURCE: Hi. I need ACRORD32.EXE to open pdf files I
some one with the newer version could open them then save them in some other format, than email them back to you, or possably convert them to an older format for you to open them.
also with the newest version of inter net explorer you shoud be able to open it on line with explorer, than save it to the version that you have.
Posted on Sep 30, 2009
  • 1027 Answers
SOURCE: I can't open pdf files.
try install acrobat reader
you can download hare
http://get.adobe.com/reader/
Posted on Feb 18, 2011
I can't open pdf files. As AcroRd32.exe-- entry point not found
Feb 18, 2011 | Computers & Internet
Cant open pdf
Make sure only adobe 9 is the only version of adobe reader you have installed on that computer. Then go to where your PDF file is and right click on it with the mouse and go into properties.
In the general tab where it says type of file it will show you what program is opening up the PDF file. Click on the change button and where it says recommended programs see if Adobe reader is there, if its not then down below where it says other programs click on the down arrow and see if adobe reader shows up there. If it shows up in either section then choose it, then click on apply, and then click on okay.
Now if for some reason adobe reader doesn't show up in either section, then you'll need to browse for it. It normally installs itself in the program files folder, then double-click on it and go into the adobe folder, Adobe 9.0 and then the reader folder. The name of the reader program looks something like acrord32 and it will say application to the right of it. At that point choose it and apply the changes so it opens up with Adobe reader.
This should cover everything, if your still having problems, let me know and I'll help you out further.
May 22, 2010 | Dell Dimension 4600 PC Desktop
Hi. I need ACRORD32.EXE to open pdf files I receive via email, including image files in pdf format. I tried getting updates on ADOBE Acrobat, but currently I have an old laptop (1998) and only Win98 as OS....
Sep 30, 2009 | Microsoft Windows 98 for PC
Adobe Reader version 8
Try this fix,
1.dowload windows installer cleanup utility from the following link.
http://support.microsoft.com/kb/290301
Under more information, tab
2. Install and run the same from Start> All programs>windows installer cleanup utility.
3. In the box keep on selecting all items that say adobe and click remove. If you have multiple enteries might need to select them one by one.
4. Click on Start >My computer>Local Disk C:>Program files and delete the adobe folder
5. Restart your computer and again download and install adobe reader , it should work fine .
In case it still does not work and you need to open pdf files download
foxit reader from the following link
http://www.download.com/Foxit-PDF-Reader/3000-2079_4-10313206.html
Thanks
Mandeep
Jun 07, 2008 | Adobe Acrobat 7.0 for PC
Converting from to pdf from the web and won't open
If you are using acrobat professional, uninstall the application completely.clean the registry using some registry cleaning software (tune up utilities for example). Restart the machine. Reinstall acrobat professional.
May 23, 2008 | Adobe Acrobat 6.0 Professional for PC
Acrord32 error
try to uninstall Adobe and install it again. It helped me.
CS.
May 16, 2008 | Compaq Presario 5000 PC Desktop
How to open PDF files with Adobe
Witch version your install first tell me I think your install acrobat 5.0 (simple) Click Start go to run type AcroRd32 press enter then open pdf supported software open next go to file menu click open wear your files is their then open ok http://www.adobe.com/products/reader/productinfo/faq/ support see this web
Mar 12, 2008 | Adobe Acrobat 7.0 for PC
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
