Kaiser baas has white lines
Kaiser bass photo scanner has white lines have cleaned and calibrated as per instructions
3 Suggested Answers
SOURCE: Visioneer Strobe XP 100 - Vertical lines on photos
I lost my software Driver of Flatbed scanner D1250u2f. So, I want to download a new for my scanner. Where Can I get it; can you help for getting it.
Posted on Feb 08, 2009
SOURCE: pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Posted on Jul 13, 2010
How do I set up the kaiser baas bt-320?
Is the device a BT 280 or a BT 320 and what device are you trying to attach it to?
Feb 12, 2015 | Kaiser Baas Bluetooth Keyboard Bt-280 -...
How do you use a surf board mount for the kaiser baas x100 camera
I think the question is somewhat fuzzy. If you try to be more specific and, if possible, attach the picture it is much easier to discuss the techniques used.
Jan 26, 2015 | Cameras
Cant install driver ACPI\AWY0001 I am unable to use my Kaiser Baas scanner with photoimpression 6. Do I need to download a new version to the driver?
try to remove first your anti virus or set it off but you must unplug internet connection before you install your driver again , thanks . good luck
Jul 10, 2011 | Computers & Internet
I have been given a KB Photomaker (KBA03005) ; however I use a Mac. Is there a driver I can download?
The PhotoMaker model that you have is PC only. The manufacturer does not supply MAC drivers for this chipset unfortunately.
We're working on a MAC model, which will be available around April 2010.
You could also consider the PhotoMaker Pro which captures directly to an SD card. You then use your MAC to edit the photos.
Regards Murray Kaiser Baas www.kaiserbaas.com
Jan 04, 2011 | Computers & Internet
Need a driver for photomaker by kaiser baas using vista
Hi amour459,
Have you found a solution to your problem?
I work at Kaiserbaas and hopefully can help you, alternatively, you can go onto support site http://kaiserbaas.helpserve.com/
Pam
Feb 23, 2010 | Arcsoft PhotoImpression® 6 Full Version...
Pandigital mini photo scanner pictures have white lines on them
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
Xerox Documate 152 - Scan quality is now V.BAD!
I would go to Xerox.com and look up their knowledge base. Here is a copy of data from their site related to this problem:
Symptom: Scanned images have poor image quality, are fuzzy, unclear, or hard to read.
Cause: There are several things that can lead to poor image quality including the scan settings, dirt on the scanner, and driver problems. Solution: Note: If you scan as a PDF file and your scans look fuzzy when viewed in PaperPort, try right clicking on the file and selecting "Open" to open them in Adobe Reader. If they display fine in Adobe Reader then there is nothing wrong with the scans, it is simply that they are not being displayed well in PaperPort.
The following solutions can help resolve poor scan quality.
Solution 1 - Adjust the scan settings
Try increasing the resolution of your scan. 300 dpi to 400 dpi should be clear for most images
  • If you are scanning in Black and White, try Grayscale or Color. Some images will not display correctly in Black and White
  • You can also try adjusting the brightness and contrast
  • Note: For information on adjusting your scan settings, refer to the user guide for your scanner
Solution 2 - Clean and Calibrate the scanner
Note: Calibration only applies to sheetfed scanners.
Use the link below for instructions on cleaning and calibrating (if applicable) your scanner:
Solution 3 - Reinstall the scanner driver Select a link below for instructions on reinstalling your scanner driver:
Jul 08, 2009 | Xerox DocuMate 152 Pass-Through Scanner
Feb 07, 2009 | Visioneer XP100 Strobe Mobile Scanner USB
k24674
