Question about Kodak Easyshare CD82 Digital Camera
Broken door the battery door won't shut because it's broken
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
I can only say bring it to the dealer where u bought it and let it repair
Posted on Nov 24, 2013
2002Dodge caravan sport won't start.New battery and altinator.
something on in your car is sucking the juice,a door not closed completely or inside lights left on or headlights or parking lights dome lights,ignition not completely shut off,hood light trunk light etc check them all,if car turns over when charged but wont start it could be your fuel pump or broken timing belt
Jan 16, 2013 | Dodge Caravan Cars & Trucks
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
Interior roof lights won't go off
This can be caused by a door or trunk being ajar, be sure you shut all doors firmly, if there is still no resolve check by shutting all doors then open one up and press the button (if any) on the inside of the door jam and see if it is broken or the light goes off.
Jun 04, 2012 | 2007 Audi A4 Avant
My Nikon Coolpix L24 camera's battery compartment spring-loaded latch is operational. However, the lock appears to be missing or broken and the door won't stay shut.
I had the same problem. I found out that the rubber band that is used for celery can be wrapped twice around the camera. Works great.
Oct 27, 2011 | Cameras
The door that holds the batteries in will not stay shut i believe maybe where you slide it shut a piece of that might be broken is there anyway to fix that or do i just need to hold it closed and hope for...
Pull the batteries out and see if it will stay closed, if it does the batteries are installed incorrectly. If it still won't stay closed your options are to either tape it shut or get a new camera unless it is under manufacture warrenty still or you have an accidental damage plan.
Jul 28, 2011 | Olympus FE-210 Digital Camera
2007 Hyundai Accent the driver side door won't open from the inside. It opens from the outside so I have to roll down the window and open the door before i shut the engine off.
Either the interior door handle or the cable inside the door is broken. You'll need to remove the door panel and look to see what is damaged.
May 25, 2011 | Hyundai Accent Cars & Trucks
The batteries keep popping out when I open the case.
Your battery door or surrounding casing is broken. It's a common problem with this model (especially for units with the side battery door). Unfortunately, your only options are to tape the door shut or get a new calculator. If only the door, and not the casing, is broken you can try to find just the battery door.
Feb 15, 2010 | HP 19bII Calculator
Broken door
Tape it shut is the only solution here No Spares no Repairs.
Jul 06, 2007 | Pix S-470S Digital Camera
Kodak Easyshare CD82 Digital Camera Logo
35 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
