Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
My kenmore 6651304 sounds like it wants to stay on then it shuts off
The motor turns on an it starts to cycle the water, then in 10 seconds it stops and does this over and over. This doesn't seem normal?
  • 58 Answers
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Posted on Jan 09, 2009
rpbuice
  • 161 Answers
SOURCE: No water coming in
Check the float.
There is a float inside the dishwasher but you can't see it. The small dome in the bottom has a float inside that activates a switch underneath by a plunger. Sometimes this float gets stuck in the up position. Take the bottom panel off and look directly under the dome for the switch and the plunger that activates the switch. Push this plunger up to see if it moves freely. If it moves then you need to check the switch then the water valve solenoid with an OHM meter. Next, use the meter to see if the timer is sending power (110) to the water valve.
If everything is good to this point then check the water supply. Turn the water supply off, disconnect the water line from the dishwasher water valve, run a small amount of water into a pan.
Hope this helps.
Posted on Jan 18, 2009
  • 188 Answers
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
arikrom
  • 528 Answers
SOURCE: I have a Kenmore dishwasher and recently it seems
water not getting to the unit as they should be or your pump is clog with left over you will need to take the spray arm out and get to the pump and clean it.
watch for broken glass!!!
Posted on Jan 01, 2010
rylee_smith
  • 8619 Answers
SOURCE: My Kenmore Dishwasher 665.16359301 quit
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If still the issue is not resolved then to resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 20, 2010
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
Jun 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
I own a kenmore top loading machine model number 110 10 amp 60 hertz 120 volts the machine gets power and runs but the big control knob that controls the diffrent cycles is running only about 20 seconds...
sounds like you should replace timer (big control) timer motor is part of timer. Is timer knob speeding thru cycle that fast or just start/stop.
110 is manufacturer code for whirlpool, number after decimal is model number. tech sheet avail inside console by unsnapping left and right console covers and removing hidden screw at front bottom corners, pull forward slightly then fold console back (hinged at rear top).
Apr 26, 2009 | Kenmore 22642 Top Load Washer
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Calypso
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. This could just be a fluke, or you could have a possible bad pressure switch that is not shutting off the water supply correctly. In addition, fill valves have been known to short out causing water to constantly fill in the wash tub. Lastly, your household water pressure could be too low and won't shut the fill valves off properly. Inlet water pressure should be a minimum of 10-20 psi. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. I hope some of this leads you in the right direction.
May 12, 2007 | Kenmore Elite 21086
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
29 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
