Monitors
Problem for Monitors
Generic problem for all Monitors
Repair
By afash on Oct 10, 2007
this is monitor is dead and blinking green led
Same Problem
Nov 08, 2008
-   This is the same defective monitor sold by I-Inc. Monitor dies 14 months after purchase. The button goes from yellow to blue but will not display screen. Price is cheap because only 1 yr warranty. $93.00 to fix.....-   Guest
Nov 05, 2008
-   blinking blue - yellow. swapped cpu's, this monitor still blinks blue - yellow & no picture. swapped monitors and desktop appeared.-   tross_p3
Dec 27, 2007
-   My XG-71D also blinks on and off when I try to start up my computer. After about three reboots it finally starts to hold a picture longer then another one usually gets it to function properly. Worked fine until I upgraded from my Radeon 9600 SE to a GeForce 7600 GS. Using an 8800 GTS 512 now and it still does this. Possibly an issue with newer graphics cards? In any case I'm looking into a new monitor.-   Mikase
Nov 11, 2007
-   tried to log off on the computer to restart. now the monitor won't displany anything. The green light just blinks on & off-   Guest
Nov 08, 2007
-   I unplugged it from the computer and it changed colors then plugged it
back in and it went back to blinking green.Could it be a video card issue?
-   paxton90
Best Solution
posted on Nov 11, 2007
Helpful)
paxton90
Rank: Apprentice
Rating: 84%, 3 votes
The same thing happened to me as it did for angelinhogt.
After I left the monitor on for about an hour the monitor
just came on.
Was this helpful?
Yes
No
Solution #2
posted on Oct 10, 2007
Somewhat Helpful)
mishra
Rank: Master
Rating: 72%, 51 votes
if the monitor green led is blinking continuosly
the follow the steps
remove the cable of the monitor which is connected to the CPU and watch the monitor it should show a message ( no input signal or cable disconnected, that means your monitor is OK the problem is with your CPU . try this and let me know
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jan 19, 2009
Not Rated)
Wovencroft
Rank: Apprentice
Rating: 0%, 0 votes
I had exactly the same problem, I could see the desktop briefly then blackness. The solution to me was a different power supply. One similiar in voltage and amps and plug and it worked, the power supply was dead.
Was this helpful?
Yes
No
Solution #4
posted on Nov 23, 2008
Not Rated)
hardik220286
Rank: Apprentice
Rating: 0%, 0 votes
i am hardik,
i had the same problem of no display and green led blinking for samsung 793s monitor i removed the cable from the cpu and the monitor display me no input signal, does this means that my monitor is ok and there is a problem with my motherboard. can u mail me on hardik220286@gamil.com
Thanking u in advance
Was this helpful?
Yes
No
Solution #5
posted on Sep 19, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The VX922 is commonly known to do this after a year or two after use.
Viewsonic HAS to help you out if you are still under warranty.
Im through 2 of my 3 years, I will RMA this so they can fix it, replace it, or give me a new monitor.
Good Luck,
Douglas
Solution #6
posted on Jun 12, 2008
Not Rated)
zicherd
Rank: Apprentice
Rating: 0%, 0 votes
This problem is with the AC Adapter. You need to replace it.  Unfortunately, X2Gen is Bankrupt and finding one has been difficult.  I have 5 of these monitors in my office and switched out the AC Adapter and it works fine.  So, on goes my search for a different adapter.
Was this helpful?
Yes
No
Solution #7
posted on Apr 14, 2008
Not Rated)
Goljo
Rank: Apprentice
Rating: 0%, 0 votes
One of the inverter controlling transistors is failing. If you can see that it is burnt, you know which one, otherwise you should change both. Model # FDS8958A.
Was this helpful?
Yes
No
Solution #8
posted on Oct 18, 2007
Not Rated)
angelinhogt
Rank: Apprentice
Rating: 0%, 0 votes
I have exactly the same problem!
i did what mishra said, but monitor still dead and power inicator is still blinking green.
i tried restarting the computer, and nothing, changing computer, disconnecting power (monitor) and connecting again , and nothing.
It revive without a reason (just exactly as when it died)
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
My monitor is getting off with a orange light while iam in work. This problem is getting with in 10... (More)
Answer
sơ đồ cổng 15,1 lcd moniter giúp... (More)
6 Other Users Have The Same Problem - Continued
Comment by LL09, posted on Nov 02, 2007
Having the same problem. Tried it on a different PC, still the same black screen with blinking green power light. Disconnected the signal cable, screen is still blank. Tried the menu button, nothing! Is it time chuck this monitor in trash bin???
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Monitors:
Top Monitor Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
