Question about Cameras
Exploded view lens not resetting to closed position when camera switched off
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Lens has been knocked by the sounds. Unfortunately needs to be sent in for repair.
Posted on Nov 26, 2013
SOURCE: Lens cover closed
this is easy to fix. in fact, i just did it on my camera about 2 minutes ago and came back to this post because i was originally looking for a solution myself. anyway, you have to be a little bit rough with the camera to fix it. on the outer lens cover you will notice that there is a metal cover on top of the plastic slider. you need to pry the two apart. there is some seriously sticky tape that is holding the metal cover to the plastic, so you need to be careful that you don't rip the whole thing off. once inside you will see a copper contact that (when you slide the lens cover) makes contact with another piece of metal. when i took a look at mine, it was covered in a bunch of lint. i used a q-tip to clean both contacts and then made sure that they were properly aligned. after that, i slid the lens cover back down and voila! works everytime now. use some superglue to put the metal cover back on again.
Posted on Jun 24, 2007
jackboy
  • 2985 Answers
SOURCE: the camera len will not open
Sonsy customer support for this one a strange firmware problem indeed.
Posted on Jul 31, 2007
jbreth
  • 69 Answers
SOURCE: Cybershot camera lens cover closed
Follow the steps below to troubleshoot if the lens will not open, retract, or extend. WARNING: There is a risk of hardware damage. Do not attempt to manually force the lens in or out. Doing so may damage the camera. NOTE: Because each of these steps represents a possible solution to this issue, check the camera status after completing each step. Ensure the battery is adequately charged or connect the AC power adapter (if applicable). Perform a power reset. If the camera lens is still not operating correctly after completing the troubleshooting steps suggested, service will be required. Hope this helps
Posted on Aug 26, 2007
t00nz
  • 4738 Answers
SOURCE: dropped Nikon Coolpix L3
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
dlundmark
  • 797 Answers
SOURCE: camera lens will not close
Hi:
Sometimes you can try to get it unstuck by looking at the lens at is is. Then determine if it appears to be at a slight angle, if so, it may be that you can force the lens in the opposite direction. This may not work, and may damage the lens further, however, since it is not working, trying may be just what is needed.
I have had some success by forcing the lens in the opposite direction as it is turned on with pressure of my fingers pushing it. It has not always worked, but I have two which worked just fine... one was a 7.1mpxl nikon and the other was a 8mpxl Canon.
They both were off track, and jumped back by a little force.
If the lens was hit or dropped, then damage can be more than can be fixed. What can happen is that the small track parts can be broken, then there is no way to get it back on track.
Also, dirt or sand can do a number on these small parts. It is amazing how these extremely small pieces of sand can jam a lens, but I have seen it happen.
Take a hint and keep the camera away from sand and water, or risk trouble.
Posted on Jun 21, 2008
Kodak Camera DX 6490 is frozen in the open position and will not respond...open
Does not look good at all. Try this:
remove the battery. Charge the battery, or place another charged battery. Close the battery cover and switch the camera on.
I hope it now will retract the lens.
Most of the time you only can manage to freeze a camera with the lens in that position, when you remove the battery. That is unwise, because the camera does not know in what position the lens is, when you place the battery and switch on.
If the camera was switched out correctly and it could not retract the lens, it could be there is a mechanical problem in the lens barrel, or the motor (steering) is defect.
Sometimes camera's just die too.
I wide you luck while reviving your camera.
Jan 19, 2014 | Kodak EasyShare DX6490 Digital Camera
Nikon d80 won't turn off. Stayed on after viewing slide show on TV. Operates properly with switch in "off" or "on" position. Tried:1. removing battery. it restarts with switch...
It may be as simple as a broken or worn out on/off switch. If the switch shorts out, the camera will always be on or always be off. The problem could also be the switching circuitry. If you need service, you should call Nikon's Service Department at 1-800-NIKON-US (1-800-645-6687)9AM-8PM EST, Monday to Friday.
Sep 20, 2011 | Nikon D80 Digital Camera with 18-200mm...
My camera (s1075) is not taking any pictures or lettin me view my pictures due to the lens being frozen. it is stuck between open and close state and so will not open when i switch the camera on nor will...
Sorry, it doesn't sound like a quick fix is going to work here. The lens sounds like it took a pretty good hit and may be misaligned now, which is keeping it from fully retracting. Your best bet is a service center at this point.
Oct 20, 2009 | Samsung S1070 Digital Camera
Camera was dropped in use and the lens has half closed and jammed! The camera will not turn on even to view the pictures on the memory card. Is there a way to reset or manually close the lens? Also do you...
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 20, 2009 | Casio EX-Z1050 Digital Camera
Lens error, restart camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Black screen
Some cameras have a switch (usually above he screen) that allow you a choice of viewing the screen OR viewing through the viewfinder/lens. Try to locate that switch on your camera.
Sep 12, 2008 | Cameras
The cover for the lens has fallen off
you can view and touch broken portion in on position remove battery still lense is out , remember this is very sensitive parts might it will broken let camera technician do it for you.
Dec 29, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
LCD and lens not working
This is a circuit board failure contact Canon customer support
Mar 04, 2007 | Canon PowerShot A95 Digital Camera
Lens won't retract : /
Another common problem. Lens troubles. You have either knocked your lens out of alignment or you have a foreign body jamming up the works in the lens control unit. There have been many so called fixes for these problems but usually end up causing more problems than curing. You could check that you have fully charged new batteries. Some cameras need that extra kick to get them to open the lens fully. Worn out batteries can stop a sticky lens in it's tracks and tell the processor there is a problem and to close down. It's well worth trying before writing it off.
Jul 06, 2006 | Panasonic Lumix DMC-FX8 Digital Camera
Cameras Logo
63 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
