Ricoh mp 9000 sc 593 - Office Equipment & Supplies
SOURCE: I am getting an error code SC 534 on my Ricoh
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Posted on Aug 05, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Ricoh Aficio MP 4000 sc 870 error after power cord
SC870 = Address Book Data Error. This is most likely a hard drive failure especially considering the power loss. This is about a $175 repair in case you want to call around locally and get estimates to replace the drive. There is an outside chance you can get someone to walk you thru the Service Mode and do the following to reload the address book:
1. Enter the SP mode
2. 5846-50 (Initialize All Address Book)
3. Turn the machine off then on again.
Good Luck
Posted on Oct 20, 2009
  • 3 Answers
SOURCE: eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Posted on Apr 11, 2010
  • 393 Answers
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Posted on Nov 15, 2010
SOURCE: Sir, My copier model RICOH MP
My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 101
Posted on Nov 18, 2010
What is the solution for Ricoh mp 2000 sc 309 error?
Nov 19, 2015 | Ricoh Office Equipment & Supplies
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
MP 9000 SC 124 What is the solutione please?
SC 124 Scanner error Check and clean white plate
Scanner error Check exposure lamp /comming on -Carl
Feb 23, 2015 | Ricoh Office Equipment & Supplies
Richo infotec 3090 SC 593
- Toner Suction Motor Replace Alert.
- The total operation time of the motor exceeded 600 hours.
- The toner suction motor has reached the end of its service life.
- You can try rest it, after some time it will start to print light prints.
- So you will need to replace it.
- You can clear the code in Service Mode.
- To enter into Service Mode you need to follow the next procedure:
- Press the following key in the following order:
1. Press Clear Modes [yellow key] .
2. Press 1 - 0 - 7 [ with the blue keypad numbers ] .
3. Press and hold down Clear key [ C key] for 5 seconds.
(after release of the C key, the Touch Screen will change)
- On the touch screen press the [Cop SP] .
- Press the following number with the blue keypad:
[ 2 - 9 - 7 - 3 - 0 - 0 - 1 ] then press [ # ] .
- On the right side of the touch screen should write the following:
[ Toner Suction Motor Operation Time ] .
- Press [ 0 ] with the blue number keys, then press [ # ] .
- After doing all of this re cycle the machine by turning it off,
wait for 10 second, and then turn in on with the main power switch
[Red Power Switch] .
----------------------------------------------------------------------------------------*note: the machine will work again with this procedure but maybe,
after some time, or maybe even immediately after this,
the machine will start to make light prints.
Mar 12, 2014 | Ricoh Aficio MP 1600SPF Black Toner...
Sc 440 in richo afichio mp 9000
hellow my mp 9000 send massage as SC 180 what does it mean and how can i solve it, need rapide help please.
Sep 08, 2013 | Office Equipment & Supplies
CODIGO DE AVERIA SC 553 RICOH MP 8000
la fotocopiadora marco sc553 y no se desbloquea que debo hacer
Jan 31, 2013 | Office Equipment & Supplies
Ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
106 people viewed this question
k24674
