Question about iRobot Roomba 560 Robotic Vacuum
Irobot roomba model 537 charging error
Charging error 3
  • 61 Answers
SOURCE: need owners manual for irobot 4100, roomba
The iRobot website has all the manuals available on their troubleshooting page. Just search for "manual." You want the 400 series one.
Posted on May 15, 2009
  • 61 Answers
SOURCE: iRobot Roomba Dirt Dog sounds weak and stops
Generally the unit will beep or play the "uh-oh" tone or do something. I wish I could tell you what's going on with this Dirt Dog, but it's not communicating the problem. The best thing to do would be to give us a call when you have the robot with you. That will enable us to do any necessary troubleshooting as well as set up any orders that might be necessary. We're here M-F, 9a-7p, and Saturdays 9-6, EST. 1-877-855-8593 Look forward to hearing from you!
Posted on Aug 27, 2009
SOURCE: i have the irobot roomba and the battery does not
The Roomba has a rechargable Battery. The Roomba battery like any battery will eventually ware out after so many charges and discharges. Mine lasted about three years and then is would hardly hold a charge. I purchased a new battery and then it worked fine after that.
As for not going forward. That is usually due to a dirty bumper sensor. You have to take the Roomba apart for cleaning that. You can take it to Sears and they will do it for you.
Posted on Oct 02, 2009
SOURCE: I have iRobot Roomba 4210 and I have a problem
The charging circuit on the main board is fried. This is a common issue. You need some good electronic repair skills, and equipment, to replace the problem components
Posted on Jul 24, 2010
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Scooba 5800 starts to charge then beeps loudly
1) test the batteries very well in another device.
2) test the charges if working properly.
3) test the power inside from scuba, some electronic components like diode, or capacitor is draining the batteries. repair or rreplace.
God bless you
Sep 19, 2012 | iRobot 5800 Scooba Vacuum
My roomba 550 is having an error code 3. I change the power supply and the problem still. I will appreciate your answer
Your error code is a charging fault code
By clicking ojn the link below is a chart of fault codes. Save this useful chart for further use later
http://www.robotreviews.com/wiki/troubleshooting-roomba-5xx
Apr 11, 2010 | iRobot Roomba 550 Vacuum
Charging error 5 - battery not workiafter 4 calls and 4 different
Generic works fine, and that charger does too. If your charge light and dock light are on then you'll be okay.
Save cash, go generic!
Mar 03, 2010 | iRobot Roomba 560 Robotic Vacuum
Trilobite (red version) Error Code 3
If you can't find proper service from your country, please send your Trilobite to Finland
So have done some other people around europe too! :)
I am a professional with Trilobite robot's.
No service manual available, even for me...
For error 3 If you can't find proper service from your country, please send your Trilobite to Finland
For error thre is several possible reasons.
Check first all visible, is the surface clean and no visible damages.
If OK, yuo must sent it to service.
Br Jari Viitanen
Address for service is:
Oy JVV Tekniikka Ab
Mestarintie 43
SF-28800 PORI
tel. int +358 400 126597
remember add your return address with short description of fault and put the charged in the parcel
Oy JVV Tekniikka Ab
Mestarintie 43
SF-28800 PORI
Nov 25, 2009 | Electrolux Trilobite Vacuum
My Trilobite starts and runs for about 3 minutes (on plain parquet floor) when it suddenly stops with error 5. One is supposed to clean the role. I did it but the problem remains.
Mostly error 7 will be repaid for arroud 200 euro plus delivery costs
Oy JVV Tekniikka Ab
Mestarintie 43
SF-28800 PORI
Jun 29, 2009 | Electrolux Trilobite Vacuum
iRobot Roomba 560 Robotic Vacuum Logo
151 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
