Question about Franke Replacement Cartridge For Frxs2 Filtration Unit
Unit leaks after changing filter - Franke Replacement Cartridge For Frxs2 Filtration Unit
    Master:
  • 403 Answers
I have one of these units, just replaced it last night. First off, determine where it's leaking. The filter cartridge is generally inside a cylindrical cup with a screw thread at the top. Leaks here would either be that the wall has a hole in it (replace the canister), the male threaded area has been damaged and is not round (replace the canister, the mating female thread is damaged or out of round (replace that part), or you're leaking through where the threads meet. (If the leak is not in this are, then the leak-fixing turns into generic plumbing - find out where the water if getting out. If it's hose, replace the segment, if it's a valve, replace the valve or valve seat.
Assuming it's the filter holder - check both thread faces for contaminants or grit. Some filters (like mine, fed with well water, come out covered in gack. If that gack- fine sand/silt from the water, gets in the threads, it can create a widening there on the thread that the screwing-in just spreads down the thread. In any case, clean both surfaces carefully with a clean, lint-free cloth.
After that, I've had great success wrapping a couple of circles of plumbers teflon tape onto the male thread of the filter holder. Get a roll of reasonably wide teflon plumbers tape and run it clockwise (looking down from above the cup) around the thread 2 or three times, keeping some tension on the tape, and then tension tearing the tape. Smooth it down, clockwise. Now mount the filter to the screw in point, and then carefully screw in the filter body. You wrap the tape this direction so that tightening the screw will tend to flow the outer end of the tape toward it's end, rather than back on itself. hand tighten, and then, when firm, tighten another quarter turn or so. The tape will do a great job of sealing the slightly larger gaps between the threads, and probably fixing the leak.
BTW, good pricing on the filters here: http://bit.ly/1Opkuh8 though back ordered at present, and here
http://bit.ly/1Rwg9q0
Good Luck!
Posted on Nov 04, 2015
How do i change the filter in the amana my ice taste bab do i need to cut the water supply off to change the filter
Water filter is located in the upper right hand corner of the fresh food side.
Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
Sep 14, 2011 | Amana ASD 2624 Side by Side Refrigerator
Leaking where filter unit connects to block.
Oil filter adapter leaking ?, or bad gasket on oil filter, you can try tightening it, remove the oil filter and tighten the nut, i have never had any luck stopping the leak on either the adapter or filter with out changing the gasket/o ring, sorry with the information you supplied I can only guess.
Have a good day.
Mar 12, 2011 | Mercury Marquis Cars & Trucks
I have oil coming from the oil filter houseing unit?
It is possible that it could be leaking oil from the oil filter adapter (Sometimes called housing) where it mounts to the engine block. Leaks here are pretty rare. More likely, your oil pressure sending unit is leaking oil. It screws into the back side of the oil filter adapter and can sometimes make it look like the adapter is leaking.
Dec 27, 2010 | 2006 Chevrolet Impala
My audi has a oil leak of some sort which is leaking into the air filter unit and has soaked my air filter, the oil leak is coming form aline that runs along the top and side if the air intake unit. why...
follow the line backwards down to the block and clean the breather(if fitted) this is not an oil leak, the pipe is there to **** up the engine pressure when decelerating.........the air filter should be changed every 20 thousand miles/2 years.....
Sep 14, 2010 | 2002 Audi A4
Leak at one of the fittings on my Culligan RO system
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
Aug 01, 2010 | Culligan Under Sink Water Filter
Has a bad oil leak coming from under the car . The only time it leaks is when the car is running, was told that it could be the oil pan gasket or the oil sending unit, what I wanted to know is where the...
The oil pressure sending unit screws into the engine block so you will need to look between the oil pan and the head.I suggest that you try tightening your oil filter first.
Dec 21, 2009 | 2001 Ford Focus
Control unit not working - blinking
i dont really understand, but if it a residential split and you have water in the emergancy pan underneath the indoor unit there is a float switch in that pan that is open not letting the unit come on it is there to prevent water from leaking throgh the ceiling.
drain that pan and unit should come on however something is wrong. when is the last time yuo changed the filter 9 times out of ten that is the problem if filter is changed and indoor motor not running that will cause unit tice up causing leak, third the which is unl,ikely you have a leak. if i can help you anymore please let me know
Sep 15, 2009 | Heating & Cooling
After changing coil on a/c unit, it still has a leak!
a leak, other then in the a-c itself, should have been found when a vacuum was pulled on the system before it was recharged, also the dryer should have been replaced at this time, since the system was open.
Aug 03, 2009 | Heating & Cooling
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
Franke Replacement Cartridge For Frxs2 Filtration Unit Logo
561 people viewed this question
Top Franke Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Franke Water Dispensing and Filtration Expert? Answer questions, earn points and help others
