Question about Plumbing
How do I disassemble delta model 11946-SD handle to replace ball assembly?
jj505
  • 195 Answers
SOURCE: delta shower faucet
Please read here first:
http://www.plbg.com/forum/read.php?1,342033
You may need to call 1-800-345-DELTA (3358) or email them at customerservice@deltafaucet.com.
Posted on Mar 16, 2009
  • 659 Answers
SOURCE: how do i disassemble Delta Innovations Centerset
So I believe based on what you are writing, it's a double handle style faucet. So you loosened the set screw that holds the handle on which is located near the top of the handle close to where you would grab. I would totally remove it from the handle just to make sure its not catching on a burr. If you have pulled and it will not come off, you will have to use a handle puller. Your local hardware store should carry them for less than $10. When you see the puller, it will be self explanatory on how to use it. Sometimes the handles can be hard to remove especially if they haven't been removed in a long time. Worst case is that you will have to cut the handle off and replace both the stem and the handle. That can be a little more costly. Hope this helps.
Posted on Mar 21, 2009
buffalonyman
  • 1865 Answers
SOURCE: Replace entire valve assembly
You can drill a small hole into the set-screw and use an easyout to extract the set screw
Posted on May 07, 2009
  • 21 Answers
SOURCE: I do not know how to remove the spout from a Delta
You shouldn't have to remove the ball to take the spout off. It simply slides onto the post. Simply rotate it back and forth while raising it up, it should slide off directly towards the ceiling.
Posted on Nov 16, 2009
  • 349 Answers
SOURCE: disassembled handle and initial pieces under
Take handle back off and see if it has a dial that can be removed and repostioned. take off and move it about 1/4 turn counter clockwise and reinstalled and try to see if mixture is correct.
Posted on May 18, 2010
HOW DO I INSTALL A SEAL KIT
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    Delta single lever faucet leakingafter bing shut off.
    Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
    Jun 26, 2010 | Delta & Single Handle Shower Faucet
    How does the cap assembly rp4993 come off, or do you have disassembly instrutions you can email?
    The part number rp4993 I believe are the seats and springs for Delta faucets. Be sure to turn off the water before you begin. If you are working on a Delta, I am guessing a single handle. Then once you have removed the handle, the bonnet or cap should be exposed. There is a little grooved section that goes around the bonnett that you can grip with pliers or a pipe wrench. It should unscrew counter clockwise. Once this is off you can remove the ball and seats and springs to replace. I hope this helps.
    May 08, 2010 | Delta T13420 Chrome Classic Single Handle...
    Slow drip from Delta single lever shower faucet
    remove handle with allen wrench then unscrew sliver ring that covers ball with stem sticking out you might need a strap wrench if the threads are corroded
    Mar 07, 2010 | Home
    Repairing a delta single shower faucet. The handle comes off easily. Should the ball assembly just pull straight out or is there something else that needs to be loosened. I bought new seats and springs to...
    There is a nut that needs to be removed, allowing you to remove the ball assembly.
    Look at the ring nut right below the #1 in this pic.
    Your's should be similar to this one.
    Oct 03, 2009 | Delta & Single Handle Shower Faucet
    May 04, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
    Replace the seal on the 470 DST single handle pull out faucet
    Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
    Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
    Leakes around spout
    You remove the handle after turning the water off the to faucet. Remove the retaining nut which is apart of the trim. The ball assymbly will pull right out and you will find the two little washers and springs below the ball. You can buy a rebuild kit with the new ball if you like but it is not necessary. When you do replace the washers, it might be necessary to tighen the tension ring that is on the retaining nut. Tighten it unit it doesn't leak around the ball stem.
    Apr 02, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
    Plumbing Logo
    104 people viewed this question
    Top Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
