Question about Sunpak (SDPF-070AW-0US) Digital Picture Frame
Mustek digital frame says no playable file - Sunpak (SDPF-070AW-0US) Digital Picture Frame
Trutech 7 Digital Photo Frame
Hi ,
Can you copy and paste your files into the computer? If so, you problem is that you click on the, and then a program opens and it say no playable file?
Jan 12, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Can a sdhc card work on a mustek pf-b800?
Only your manual can tell you that. Find out what card is compatible AND make sure you format it first using your digital photo frame settings software. You manual will tell you how to do that.
Always works better that way.
Dec 22, 2009 | Mustek Pf T80B 8 Inch Digital Picture...
I lose my user's manual and I don't know how to use the unit in safe manner.
You should be able to find a downloable manual in the following link.
http://www.mustek.com/mustek/Support.php
If you want to save files from being deleted, you can lock files by using the options in the Mode setting which is the > icon on the round dial.
You can also call Mustek at (949) 790-3800
Oct 23, 2009 | Mustek 5 MP Digital AV Player / Recorder...
Can't get frame to read files on USB flash drive
keep the drive you use to 2g or 4g max.for some reason a lot of the cheap frames cannot handle anything bigger.
Mar 29, 2009 | Nextar N7 - 7 Digital Photo Frame with...
I've got a LOGIK PF-A850WD 8.5" digital photo frame. I've copied photos onto an INTEGRAL 512 MB. When i try to view photos the frame says NO PLAYABLE FILE. How to I fix this/
Please make sure that the photo files are in the root directory of the memory photoframe (ie, not within a folder).  That they are in a readable file format (.jpg) Check to see that the frame is reading from the internal memory and not the card slot.
Dec 12, 2008 | Acer AG.MP3F2.512 MP3 Player
I bought a technika jp07 photo frame but when i put the sd card in it comes up no playable file. i tried the same sd card in another photo frame and it works fine. please help mrs bev bartram
It seems that it's not about the size of file or resolution of the photo!
I was given one of these yesterday. I copied my photos on to a 64mb SD card of unknown make. They display fine on my PC but on my Photo Frame I get the "no playable file" message. I tried changing file size etc but no good.
As a last resort I copied my same photos on to a 2GB SanDisk SD card and tried that. It works fine. So my guess is that these photo frames are picky on what SD card they'll accept.
A pity the manual doesn't tell you so!
Nov 13, 2008 | Cameras
Get some tape, and tape a picture on top of it. Good for absolutely nothing else.
Trutech 7 Digital Photo Frame.
Try a new unformatted SD card (now they are around $10/1GB).
Sunpak (SDPF-070AW-0US) Digital Picture Frame Logo
59 people viewed this question
Top Sunpak Photography Experts
Tony
Jay Plesset
richie46
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
