Question about InFocus IN2102EP Projector
INFOCUS IN2102EP NO POWER
NO POWER
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Plugged my Infocus IN2102EP and it is
bad power supply. you will need to replace it. try projector doctor.
Posted on Mar 18, 2010
InFocus IN2102EP Projector My projector is connected to an Elmo TT-02s digital presenter that I use to show documents to my Students. When I first power on both devices, they seem to be working fine then...
Most projectors have an auto search function which can be switched off. You can then set the source to the specific input that you are using. Of the problem persists it may be the battery of the Elmo. (If it has one) Maybe it isn't strong enough to send the signal and maintain it.
Good luck.
Aug 05, 2011 | InFocus IN2102EP Projector
Infocus maching won't turn off
Try holding the power button down for 10-20 seconds.
May 04, 2011 | InFocus IN2102EP Projector
My InFocus IN2102EP projector is recently projecting a small white spot. If it was a PC, I'd say that a pixel was out. I've try blowing compressed air in various places, and have removed and replaced the...
Sounds like the DMD chip is on it's way out.
Check if the intermittent problem is related to the external air temperature. Try blowing cold air around the unit with a personal fan to see if it does the same thing.
Check if the air vents and filter is clean
Apr 12, 2011 | InFocus IN2102EP Projector
It won't power up when I press the "on" button.
does any light come on when the power is switched on, or is everything dead
Apr 09, 2011 | InFocus IN2102EP Projector
My projector went from color to black and white then the projector turned off
Sounds like a similar problem I had not too long ago. I ended up having it repaired; turned out the colorwheel broke.
Mar 29, 2011 | InFocus IN2102EP Projector
How do I open the lamp cover on the InFocus IN2102EP (to replace the lamp)? Cheers
There is a single screw that you need to remove, which will allow the panel covering the lamp to be removed.
The screw is located on the back grille, opposite corner from the power connector. For a full diagram and instructions download the following PDF:
https://portal.infocus.com/support/Product%20Downloads/InFocus_IN2102%20IN2104%20IN2106_LampReplacement_en.pdf
Mar 04, 2011 | InFocus Replacement Lamp for IN2102 IN2104...
The volume is not working on my IN2102EP, what do I need to do?
Your firmware version must be 1.11, if not, you need an actualization.
1- Check keypad and flat cable, (Replace it).
2- Check Speaker, (Replace it).
3- Check Main board, (Replace it).
Jun 13, 2010 | InFocus In2102 Projector
InFocus IN2102EP Projector Logo
57 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
