Question about Lacoste 2010651 Watch Borneo Mens - Black Dial
Manual lacoste borneo - Lacoste 2010651 Watch Borneo Mens - Black Dial
Where can I buy a replacement watch strap for my Lacoste 2500g watch?
Any good watch shop should be able to fit a band to any watch
Jan 28, 2015 | Lacoste Watches
I went to put a new battery in a LACOSTE model or part number 2000308 ladies leather strap watch only to find that there was no movement at all ???? what movement and spacer if any do I need
A watch with no movement in it is probably a salesman's sample or display model. These are often distributed to stores as part of a larger display. In addition to missing a movement, you should also check to see whether the hands have been glued in place. This is also often done because, without a movement, the hands would just flop around instead of staying in an attractive position.
Watch movements come in a variety of standard sizes and shapes. However, a standard ladies watch movement (made by many manufacturers) would probably fit your watch case. This size movement is today used in much larger watches, too; the movement is simply anchored by an appropriate spacer.
A jeweler advertising watch repair should be able to offer you a price on this job. If the hands have been glued to the dial, it may not be worth "upgrading" the watch because of the additional expense and potential damage to the watch face from getting the hands freed up.
If you're ambitious and want to try it yourself, movements can be found online at a variety of watch supply houses like Otto Frei. You can also buy a cheap new or used watch at a flea market or thrift store and use the movement from that. You might be able to re-purpose the spacer in that watch, too, by trimming it to fit your watch case. The major stumbling point here is that watch stems--i.e., the stem on which the setting crown is located--are usually custom-cut in length to match a specific case, and the one you select may be too long or too short for your case. A watch repair place should be able to replace the stem and crown for you, if you need that service. Trimming an overly-long stem is a very simple and cheap procedure; replacing the stem requires a new stem, which will add to the cost of the repair.
May 09, 2011 | Lacoste 2000308 Watches Watch for Women
I need a replacement band for my lacoste watch model 3530G
Contact Lacoste at: (309) 692-2837 use extension 508 for the parts department.
Jan 19, 2011 | Watches
I think my battery is dead in my Casio Oceanus Wave Cepter watch. It has been stored in a drawer for a couple months and it is not working now. Does it need to put in the sunlight or do I need to replace...
==== <a href="http://www.voguecatch.com" target="_blank">http://www.voguecatch.com</a> ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to ==== <a href="http://www.voguecatch.com" target="_blank">http://www.voguecatch.com</a> ====
Nike shox(R4,NZ,OZ,TL1,TL2,TL3) $35
Handbags(Coach lv fendi d&g) $35
Tshirts (Polo ,ed hardy,lacoste) $13
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,Armaini) $15
New era cap $16
Bikini (Ed hardy,polo) $18
Oct 26, 2010 | Watches
Band broke and need a replacement model 5000ss
New era cap $16
Oct 26, 2010 | Jules Jurgensen 5000SS ( ) : Swiss Quartz...
Touch screen is not working for several functions on tissot t-touch: notably started with altimeter, then meteo, now alarm.
==== http://www.voguecatch.com ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to ==== http://www.voguecatch.com ====
New era cap $16
Oct 23, 2010 | Tissot T-Touch T33159851 Wrist Watch
Just bought a Lacoste watch,and I am puzzled why they stress the importance of not changing the date between the hours of 11.45pm and 2.00am?.
If you change the date between those hours, and the watch is set for the correct time, it may automatically roll the date forward yet again. It could mess up the internal mechanism for changing the date. The date starts to change around 11:45 PM and can take a good long while for it to fully "engage" the new date, which is why they say to wait til 2:00 AM. The internal mechanics that change the date are very sensitive. If you force it to change the date while it is automatically trying to change it, it can off-set the little gears and they may not function correctly in the future. So just make sure the time on the watch is not between 11:45 PM and 2:00 AM when you change it. The best thing to do is to change the date to the day PRIOR to the day you want (for example today is the 21st, set it to the 20th, then advance the hour / minute hands past midnight so it automatically rolls into the 21st, and then you will know if you are on AM or PM).....
But just avoid setting it between 11:45 PM and 2:00 AM as they mention.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 21, 2010 | Watches
I have a bulova accutron with a 14KT gold case. it has day and date settings. there are Roman numerals around the outside of the bezel and the number e66289 mb on the back. is there anyway of checking the...
Since the serial number (E66289) begins with a letter, the watch was made in the United States. (Serials that begin with a number indicate the watch was made in Switzerland.) Look at the back again and see if there's a two-character code, such as M2. Compare the code against the list on the following link to find the year of manufacture: http://www.thewatchguy.com/pages/BulovaSerial.html
If it's an Accutron, visit this site to see if it's a 214. He's got a wealth of info on 214s! Good luck!
Nov 01, 2009 | Bulova Watch
How to set time on Citizen Eco-Drive Titanium WR100
http://www.citizenwatch.com/Technical/English/Full/E030_ebook.pdf
Nov 05, 2007 | Watches
Lacoste 2010651 Watch Borneo Mens - Black Dial Logo
29 people viewed this question
Top Lacoste Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Lacoste Watch Expert? Answer questions, earn points and help others
