Question about Sole Fitness Sole E55 Elliptical
Adjust elliptical brake - Sole Fitness Sole E55 Elliptical
Our Octane elliptical is showing a brake cable error and looking for suggestions. Thanks!
It could be that the brake is faulty or just the cable has been pulled out. It could also mean the motor is faulty. You will need to have a tech look at this.
877-805-1030
Book An appointment
Mar 01, 2016 | Exercise & Fitness
Octane elliptical brake cable
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 01, 2016 | Octane Fitness Q47ci Elliptical Trainer
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
We folded the Proform 500 LE Elliptical and moved it. Now we are unable to unfold the elliptical with the latch button. Suggestions?
HOW TO FOLD AND UNFOLD THE ELLIPTICAL
When the elliptical is not in use, the frame can be folded out of the way. First, lift the latch under each pedal arm, and lift the pedal arms off the adjustment sleeves on the crank arms.
Next, raise the pedal arms until they touch the magnets on the upper body legs; the magnets will hold the pedal arms in place.
Then, hold the handle and lift the frame until it locks in a vertical position. To use the elliptical, first hold the handle, press the latch button, and lower the frame.
Next, pull the pedal arms off the magnets on the upper body legs.
Then, lift the latches under the pedal arms, and set the pedal arms on the adjustment sleeves on the crank arms.
Release the latches, and make sure that the pedal arms are securely connected to the adjustment sleeves.
Will be attaching a link to your manual also
http://www.sportsmith.net/images/product_support/ProForm/PFEVEL959101%20-%20PROFORM%20500%20ZLE%20ELLIPTICAL/PFEVEL95910.1-307585.pdf
May 25, 2015 | Proform Exercise & Fitness
Do elliptical trainers have adjustment qualities?
Yes. Most trainers have adjustments for elevation. The elevation feature on an elliptical doesn't make the workout harder; instead it changes the emphasis so that the higher the slant, the more your glutes and hamstrings will be worked out; whereas the lower positions emphasize more on your quads and calves.
Aug 02, 2012 | Exercise & Fitness
Can you adjust the stride length on an elliptical training machine?
Some machines are sold with the capabilities to adjust stride length; which is a great feature if the machine will be used by more than one person.
Philips 777 stylus force adjustment
LM15 has an elliptical stylus so 1,5 - 1,8g should be sufficient, and also dial the same number on the anti skate for elliptical stylus and go for it
Dec 02, 2007 | Philips Audio Players & Recorders
Sole Fitness Sole E55 Elliptical Logo
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
