Question about ALEKO Lm149 Electric Lock For Swing Gate Opener Operator
Works then the gate stops opening
It unlocks then opener stops running
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
I have 2005 chevy tahoe my doors all licks but my liftgate door with window stays open use to lock w all my doors? I havent check anytjing yet? I cant lock it.
Here is how it works !
Liftgate Locking Operation
The lift gate will lock any time the vehicle is shifted out of park on vehicles equipped with an automatic transmission and at vehicle speeds exceeding 5 kph with manual transmission. This happens in conjunction with auto door locks if enabled or independently of auto door locks if the feature is disabled. This ensures that the lift gate is locked anytime the vehicle is shifted out of park or when the vehicle is in motion.
The lift gate lock relay supply and coil sides receive a constant voltage through the battery voltage supply circuit and the ECC fuse. The normally closed contact is connected to ground and the control side is connected to the body control module (BCM). A lock function will occur when a door lock switch activation, keyless entry lock transmission, auto door lock function or a lift gate lock function has been received by the BCM. The BCM will then ground the control side of the lift gate lock relay. This energizes the relay and allows voltage to be applied to the lift gate lock actuator lock control circuit. Since the other side of the lift gate lock actuator is connected to the normally closed contacts of the door unlock relay to ground, the lift gate will lock. When an unlock function occurs the BCM will ground the control side of the unlock relay and the rear doors and lift gate will unlock.
The BCM also runs diagnostics on the lift gate lock relay control circuit and will set DTC B3825 as current and also send a Class 2 message to the DIC. The DIC will display REPLACE LIFTGATE FUSE to inform the driver that a fault has been detected in the lift gate lock circuit and that the lift gate is not locked. Faults that will set the DTC and cause the DIC to display the message could be any of the following:
An open ECC fuse
An open or short to ground in the lift gate lock relay battery positive voltage circuit
A faulty lift gate lock relay
An open or short to ground in the lift gate lock relay control circuit
A short to ground in the lift gate lock actuator lock control circuit
A faulty BCM
May 14, 2016 | Cars & Trucks
How do I open the cargo door if it wont open?
rear door hatch lock repair GMC Chevrolet - YouTube
? 4:26
https://www.youtube.com/watch?v=QS3PMhGgyAg
Apr 5, 2014 - Uploaded by auto resource
2002 Yukon, rear hatch lock not locking. ... rear door hatch lock repair GMC Chevrolet. auto resource ... chevy tahoe lift gate notopening - Duration: 2:12. ... A Method how to unlock your car in 10 seconds :) - Duration: 0:35.
chevy tahoe lift gate not opening - YouTube
? 2:12
https://www.youtube.com/watch?v=xU6ybiY3F4I
Sep 1, 2010 - Uploaded by 76bluemoon
Back lift gate/glass would not open or release. Even when unlocked with the key fob or the unlock switch on the drivers/passenger door. ... How To Install Replace Rear Lift Gate handle 2002-09 GMC Envoy Chevy Trailblazer ...
Jan 16, 2016 | 2002 Chevrolet Tahoe
2008 suburban Stuck Lift Gate Lock
I have a 2008 Suburban with the power liftgate disabled. I have had the power latch stop working, and the BCM report that the rear access open when it is closed (both gate and glass). Somehow the liftgate module thinks the gate is open, so I cannot open the gate at all, and the latch and rear wiper will not work. To reset the control module I pulled the liftgate fuse (#20) in the instrument panel fuse box, turned the car on, off, reinstalled fuse, turned car on, unlocked doors using drivers side switch, and the power latch will function again - at least for a while.
Jun 05, 2013 | 2008 Chevrolet Suburban
How to unbloct facebook
There are infinite many solutions to unlock the sites. There are millions of proxy sites/servers that can help you in unlocking the sites but some times even proxy sites are also blocked. So the best way is to use some tools like
Free Gate
Unlocker
Free Gate is an excellent tool and has never disappointed me. Download the Free gate from internet, the file size is in KBs, after downloading the file run it and it will open up a small dialog which shows the progress. It will automatically configure itself and then open the Dynaweb home page for you.
On this website enter any url you want to unblock and it will unlock it for you.
Enjoy !!
Pls vote and comment if you like the solution.
Thanks.
Dec 10, 2010 | Computers & Internet
BLOCKED BY MY OFFICE
Free Gate
Unlocker
Enjoy !!
Plz comment and rate the solution if you like.
Dec 06, 2010 | Facebook Social Network
The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Gate wont open, lock and unlocked still wont open
it may be that the gate has dropped on it's hinges, try lifting as you open. (i assume a side opening gate)
Oct 01, 2009 | 2002 Ford Escape
2003 Saturn Vue rear liftgate won't open
The easy part is you just need the latch for the liftgate. The hard part is getting to it and opening the liftgate to replace the latch. You should be able to pull the liftgate trim off most of the way with the gate closed and try to manually actuate the latch to open the gate. You may have to go so far as breaking the latch from the inside to open the gate and then replace your latch.
Nov 10, 2008 | 2003 Saturn VUE
ALEKO Lm149 Electric Lock For Swing Gate Opener Operator Logo
75 people viewed this question
Top ALEKO Home Fencing Experts
crkuc
 Russ Hill
Russ Hill
ray gallant
Are you an ALEKO Home Fencing Expert? Answer questions, earn points and help others
