Question about GE Profile PXCF22RBS Hot and Cold Water Dispenser Cooler
Chunk of ice clogs unit - GE Profile PXCF22RBS Hot and Cold Water Dispenser Cooler
Ice on coil
air purifiers do not cool anything .
Jul 06, 2016 | Air Purifiers
Tip
Air Purifier Cleaning
You bought that air purifier to help to clean the air in your home. However you have forgotten about it and now you expect it to still clean, when all of the cleaning surfaces and the filter that catches the big chunks are completely used up and covered with dust and dirt.
Here is what you need to do on a regular, like monthly, basis to keep it working well.
  1. If your unit has a filter or pre-filter pull it out and wash it gently in some warm soapy water. If the filter is a throw away one then place it in a plastic bag and dispose of it. Be careful not to throw it away before you make sure you know what to get to replace it. You may need the old one for comparison when purchasing a new one. Also take note of how you removed it and the direction of the air flow. Some of the filters are made to have the air flow in a certain direction. The filter is often located in the back side at the bottom of the unit.
  2. Take apart everything that you can on the air purifier and clean all the pieces with a moist cloth. You may need to take toothpick or something small to clean out the small grooves and crevices in the unit.
  3. Leave everything dry completely before reassembling the unit. This may take quite a while for some of the filter media. A few hours is not uncommon, be patient.
You now will have your air purifier working in top condition again
on Jan 11, 2010 | Air Purifiers
Wall unit keeps frosting up, will not heat
Clogged air filter or a loose belt between the fan motor and fan wheel will cause a frost up.
Nov 19, 2015 | Mitsubishi MSZ-GE15NA Mr. Slim Wall...
Where do I connect the copper tubing line to on my refrigerator to pipe the water from the wall to the freezer so I can make ice and get cold water.
On the bottom of the back of the unit there should be a valve with a threaded fitting on it. you connect the water to this valve. make sure you put a filter in the line also.
Jan 02, 2012 | Air Purifiers
Are there filters that have to be changed and where do you get them?
Yes. You will have a prefilter and after that you will have a HEPA filter. Keep good maintenance on the prefilters which are not washable. You will need to check it once a month to see if it is time to replace. If you have good maintenance on the unit and change the cheaper prefilter, you will get years of service out of you HEPA filter. Bad maintenance means replacing the HEPA filter which is a good chunk of the cost of the purifier.
Sep 28, 2010 | Kenmore 335 CADR Air Purifier
Water drips down from Freezer. The water is coming
Since you said the water supply is shut off, the likely culprit is a clogged drain tube that connects the defrost tray to the water collection pan for evaporation at the bottom of the fridge.
The source of the clog is usually either mold growth or more likely, ice build up. Regardless of which, if you access the defrost heater in the freezer section, you can thaw ice that has collected in the tray and if needed, use a turkey baster to direct a hot stream of water at the point the hose attaches to the tray and treat the hose for mold, below.
Once cleared of ice, mix a small amount (5 or 6 oz) of water and 1/2 to 1 ounce of bleach and direct down the tube to kill any mold / growth. Be careful not to use to much or overflow, as clean up will be difficult due to the bleach mixture.
The next thing to do (if icing up) is to determine why. A careful check of the defrost circuit should be done. Otherwise, you'll be doing this over - and it may start to affect the temperatures in the frozen and fresh food sections of the fridge.
I hope this helps!
Nov 05, 2009 | Air Purifiers
I have a Living Water II installed under my sink. I would like to add a line to my refrigerator's ice-maker line. The plastic tubing supplied with Ecoquest and the line from the refrigerator ice-maker are...
Although your solution will work to supply water, the flow to the icemaker will probably not be high enough to turn the Living Water on to actually ozonate the water. Ecoquest does have a unit available, made just for icemakers.
Aug 11, 2009 | Ecoquest Air Purifiers
Condensation forms on the top inner ceiling of the refrigerator
Very common problem I have repaired many times , The drain is frozen or plugged.
remove the back panel in the freezer section to get to the evap./cooling coil , then check the pan under it , there is a small 1" drain hole at the bottom that may have ice in it or its clogged with something else.
Use hair dryer or similar to remove ice then get a wire or something similar that is firm to use to snake out and clear that drain hole you want to get about 10 inches down into it.
Pour bleach into evap pan and let it sit for a bit. [10 minutes]
Then to know its cleared well pour a cup of water into the evap pan then check the pan under the unit at bottom behind kickplate to ensure the bleach and water has made it to this pan.
If unit is now draining here , wipe remaining water off top of ref. compartment and by the next day it will usually stop.
Let me know if you have any other questions.
Phil
Apr 14, 2009 | Sharper Image Ionic Breeze GP (SI730) Air...
Under Counter Water Filter Leaking after Use Sometimes!
Got it! Your return line is clogged!
I have the same dispenser, and there are 3 tubes attached to it. One of them (black on mine) goes from the faucet to the drain pipe coming down from the sink. That line can get clogged over time with stuff coming out of your sink. You can probably disconnect that line at the drain pipe end and **** oput the connection and as much of the hose as you can get too., Reattach the line and you are done. Fire it up.
On my unit, we hear a dripping sound in the drain when the unit is charging. If you don't hear the dripping sound after using the unit, that line is probably clogged up!
See ya!
Everett
Mar 14, 2008 | Biozone Water Filters for Counter Top:...
GE Profile PXCF22RBS Hot and Cold Water Dispenser Cooler Logo
23 people viewed this question
Top GE Air Purifiers Experts
Are you a GE Air Purifier Expert? Answer questions, earn points and help others
