Question about Everbilt Hinge. 3 in. Square Corner Hinge Brass Finish 15654
Remove everbilt hinge pin
I need to remove the hinge pin
  • 78 Answers
Support the door , remove screws from one leaf of hinge, use a 1/8" punch and tap the hinge pin from the bottom. If you use grease to reinsert make sure it's white lithium grease
Posted on Feb 12, 2015
Tip
How to Reverse Your Refrigerator Door (Most units)
1. Remove the toe grille.
2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside.
3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin.
4. Lift the refrigerator door off of the bottom hinge and set aside.
5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws.
6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge.
7. Remove two screws on bottom hinge with 3/8" socket wrench.
8. Install bottom hinge on opposite side with the two screws removed from Step 7.
9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench.
10. Reverse door handles.
11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam.
12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole.
13. Tighten center hinge pin with adjustable wrench.
14. Remove cabinet and hinge hold plugs and move to opposite side.
15. Lower freezer door onto center hinge pin (if you have a separate freezer door).
16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge.
17. Flip top grille and reinstall.
18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
on Oct 19, 2011 | Frigidaire Refrigerators
I installed the Everbilt double action spring hinge. A YouTube video said the hinge needs to be oiled; the instructions do not say so and I see no hole for oil.
While the door is opening, part of the hinge as seen from the top will remain stationary and part will rotate with the door. Between them is where you'd put a few drops of oil. There's probably a couple of places this movement occurs. However, this probably won't be necessary for years but can't do any harm, especially if they get rained on.
Mar 13, 2017 | Miscellaneous
99 Chevy Silverado door pins how to change hinges
If the hinges are bolted they can be released from the bodywork and door by removing the bolts although on many models accessing the bolts can be a very difficult task.
In the case of welded hinges the door must be removed by removing the hinge pins. There is then a lot of careful grinding and cutting to remove the hinge parts from the door and the bodywork and new hinges welded into place.
In the case of a car regularly maintained, including oiling the hinges, removing the hinge pins with a dedicated service tool is relatively easy but can be extremely difficult without the service tool. Cars that have not received a high level of maintenance throughout it's life hinge pins can be extremely difficult to remove needing the application of heat, lots of hammering and repainting afterwards.
Oct 17, 2015 | Cars & Trucks
How do I remove hinge pins from everbuilt door hinge
You'll need a punch tool that has a diameter slightly smaller that the pin itself. Take a hammer and use it to drive the hinge pin out.
Sep 23, 2014 | Everbilt Hinge. 3-1/2 in. Zinc Plated...
How does one install this hinge properly?
1. Use somebody, or some clamps to keep the angle set while you mark and install the pieces. The angle is the most crucial feature. The other measurements are secondary to this.
2. Make other measurements from the center of the hinge where it pivots, not the edge of the box. When you use the center technique, you don't need to worry about distance from the back, only distance from the top.
3. With just the distance from the top and the angle set, position the top of the hinge in it's relaxed position as out of the packaging. Don't try to stretch or compress it into place. Keep the hinge as straight and square as reasonable. The rest of the measurements don't matter.
May 26, 2014 | Everbilt Hinge. Antique Bronze Universal...
How do I replace the long screw that holds the door up on the door hinges,on a '97 gmc Sonoma?
I have done a 100 of these.
The hardest part is going to be to reinstall the spring on the lower hinge arm. this is not a screw but rather a pin.
There are two hinges that hold the door to body.
when the upper and lower pins are removed the door will come away from body, it is important that before you remove the pins you take a look at the hinges.
Pay close att. to the way the hinges sit inside each other and the way the pins go in. see if they go from top to bottom or from bottom to top. also note where the copper bushings sit in hinges. each hinge has one pin and two copper bushings top go into hinge.
Over time the pins and bushings wear out ,making door hard to open and close. When the pins and bushings get so bad that the bushing is worn out and then the pins are now wearing into the hinge hole itself then this get tricky. if hinge hole is egg shaped the new bushings will not last. the door will hang again in a few weeks. this is where is get costly, the hinges now need replacing. i have gotten good at welding the holes and filing them back to shape but this takes skill or hole will be wrong and bushing will not fit or line up.
Here is a youtube video to help you.
Take note. put jack stands under door with cloth to avoid scratching door.this is to hold door when pins are removed. have somone help you, they will hold door on stands. the wires will still run through door, pull door away from body a little to allow room to work.remove the spring, it will fall out as you remove pins, remove old bushings, clean hinge area and holes,next install new bushings, apply lube to holes for pins and on bushings, slide door back on frame hinges and install pins, next slide lock washers on pins to hold pins. last is the spring. you will need a spring tool, you may rent one at auto parts store. hope this helps good day.
Feb 26, 2012 | 1997 GMC Sonoma
Need instructions on replacing drivers side door hinge pins and bushings
  • 1. Place masking tape on the inside edges of the door, on both the inside and outside of the door. 2. Remove the door spring by using a door spring removal tool. Insert the tool into the door spring, turn the knob with a screwdriver to compress the spring, then pull out the tool. 3. Set a 5-gallon bucket under the door. This will help support the weight of the door. 4.Place a nail punch under the hinge pin, and strike it with a hammer. Repeat this until the hinge pin begins to come out of the hinge. 5.Place the end of a flat-head screwdriver under the top of the hinge pin, then strike the screwdriver with the hammer to force the hinge pin out of the hinge. 6. Place the bushing on top of the new door hinge pin, and tap it into place with the hammer. 7. Insert the new hinge pin into the hinge. Tap on the hinge pin with the hammer and nail punch to force the pin into the hinge. 8. Insert the hinge spring back into the door, and release the tension on the spring removal tool. 9. Spray the door hinge with a lubricating spray or apply grease.
    I know there are a few directions but it is fairly easy to do. If you have access to an air hammer and a compressor you can use this in place of a manual hammer to make the process a bit easier.
    Hope this helps.
  • Mar 10, 2011 | GMC Sierra 2500HD Cars & Trucks
    Just changed out brass Stanley 5/8 round door hinges for satin nickel finish Everbilt brand hinges. Most worked well, eg the door closed into the jamb as before the switch. However, sereval did not due...
    Assuming these are regular **** hinges (like on full sized doors) as opposed to surface mount hinges (as on old style cabinets), you can try putting a paper shim behind the top hinge. This will tip the door away from the hinge just a bit.
    Mar 10, 2011 | Garden
    1996 lincoln door hinge adjust
    Which door is it ? If it is a front door, then it may be the hinge pin bushing that needs replacing. These can be bought at any auto parts store. Get the pin and bushing set because the hinge pin will need to be ground off to remove it. Press the new bushings in with pliers and insert the new pin from the top
    Sep 10, 2009 | 1996 Lincoln Town Car
    Everbilt Hinge. 3 in. Square Corner Hinge Brass Finish 15654 Logo
    766 people viewed this question
    Top Everbilt Hardware & Accessories Experts
    Gene Haynes
    Hippy_dd
    Are you an Everbilt Hardware and Accessory Expert? Answer questions, earn points and help others
