Question about AEG Lavamat 72640 Front Load Washer
Bra wire stuck in AEG washing machine
Bra wire has gone through drum of washing machine
  • 2 more comments
  • rjack2711 Oct 11, 2007
    Not sure what you mean by the waterproof cover, but if you mean the large drain hose connector then that is what I am about to remove and delve into the interior. Thanks for you reply.  Madam has been instructed to go bra-less in future!
  • Anonymous Mar 18, 2014
    Bra wire stuck in drum making a scratchy sound
  • Anonymous Mar 21, 2014
    How to remove drum from washing machine
  • 4 Answers
Hello, to fix this, what you should do firstly, is remove the machine from it's normal position, and then get a handyman to take off the back cover (which is not recommended by the manufacturer) and get right into the guts of the machine. Once you have found and identified the drum, internally, then open the waterproof cover, and note where are the parts and screws go. Keep digging the inside up until you ahave reached the bra wire. Alternatively, if the wire is still visivly poking out of the small holes in the drum, pull the wire out with pliers. Good luck! PS- If this information was helpful, please rate me either solved, thanks for trying, etc. Thankyou! Daniel Ballantyne
Posted on Oct 10, 2007
  • Daniel Ballantyne Oct 11, 2007
    Hello again! I am happy to read that you are trying to fix your machine by yourself, not be a PAID person! Because I'm not too familiar with AEG machines, that big hose connector would be the one to remove. Beyond that hose connector, should be something to keep the whole unit waterproof. After removing that, you should find the bra wire.
    Thankyou so much for rating me, because my work friend is a master on this website, and he told me about it. My friend said that 'You should put your wide knowledge to action.'
    Thankyou again, and Good Luck!
    Hello, it's me Daniel-son (Daniel Ballantyne) I forgot to tell you that if you have any more problems, don't be hesitated to ask me.
    Thanks for rating me again! Daniel Ballantyne.
Bra wire stuck in washing machine
You could try a very thin pair of twezers, or a very thin magnetic pick up tool,you might be luck.. if not the only other way is to remove the ruber door seal to get acces to the inside of the drum.
Dec 28, 2011 | Electrolux Refrigerators
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
Bra wire trapped in drain of washing machine noisy when drum rotates.How can I get it out?
Fishing line was looped through the larger holes in the back of the drum with a lassoo on the end of it & hooked round the wire then drawn out. A very time-consuming procedure in a confined space with a fine bendy light to illuminate the part.
Jun 01, 2009 | Zanussi FJS1225W Front Load Washer
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Bra wire stuck
you may not have to take the washer apart, take a good ligtht and look around inside the spin tub, if a part of the underwire is sticking thru, try and pull it out. Do not use the washer until the wire is removed or it actually could cut the tub and then the machine will leak $$$
Let me know the make and model if you need more assistance
T
May 22, 2008 | Washing Machines
Bra wire removel
Dont know what model you have. Search the net for a repair manual for your model machine. Some are downloadable. Then remove the tub to get to the bra wire.
Apr 12, 2008 | Washing Machines
Bra wire gone inside drum!!!!!!
DLB POST!! SEE ANSWER below From old post Solution #1 posted on Jan 26, 2008 0%20stars.png
1ad4dee.jpg Master_Tech
Rank:guru_s.gif Guru
Rating: 85%, 47 votes
you will have to open the bottom of the unit there is a pump clean out and a hose to the tub you maybe able to get it from there REMOVING the tub is not an option at this point
Jan 26, 2008 | Washing Machines
PS: have some towels handy to catch the water
Jan 26, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
AEG Lavamat 72640 Front Load Washer Logo
652 people viewed this question
Top AEG Washing Machines Experts
shaun taylor
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
