Question about Jenn-Air JGD8130 Gas Cooktop
Model # 629.1210381 jenn air stuck valve
One of the gas burners is very hard to turn. It striped the knob which I have replaced.
fridgetech
  • 473 Answers
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Posted on Oct 19, 2007
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
rylee_smith
  • 8619 Answers
SOURCE: Jenn-Aire ccg2523 Natural Gas sealed cooktop.
Hi
It seems like you got water into the ignitor switches on under the knobs. Sometimes it takes 48 hours for this to dry out. Or you can pull the knobs and use a hair dryer on to dry out the switches. Also you can try to clean it. Please refer to the link and picture: e11b706.gif Please do accept the solution and revert for further assistance. Thanks Rylee
Posted on Jul 03, 2009
localwonder
  • 6784 Answers
SOURCE: all cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: burner valves stuck and will not turn.
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 18, 2010
Turn on one burner, second burnertrise to light
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
Sep 12, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Jenn-air ccg2520 burners will not ignite - no clicking- cn anyone help
check for power by pluging something else in, did it get somthing spilled in it, compressed air blown under knobs removed should doit or just wait for it to dry out are all the burners affected
Jul 01, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Flames too high Jenn-air CCG2423
Definitely cut your loses and get a cooktop with a warranty. That unit sat on the back shelf for a reason.......it didn't work properly.
Also, but a cook top that is compatible with the safety knobs they sell as child guards at places like lowes and home depot.
here is a link to show you how the child proof knobs work
http://www.associatedcontent.com/article/327577/childproof_your_stove_safety_1st_stove.html
Jun 20, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jenn-Air Expressions cvgx2423b manual request
I have the same model with the same problem. The replacement is simple. Remove the burner cap (no tools needed) Take a large crescent wrench and remove the large center nut holding the burner assembly in place. The ignitor will slide out of the assembly once it is removed. Good luck
Aug 14, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn Air gas cooktop
pop me an email at b4829@yahoo.com and reference your cook top you can rate me later
Mar 29, 2008 | Cooktops
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air JGD8130 Gas Cooktop Logo
56 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
