Question about PfaFF Sewing Machines
Pfaff 3 0 coverlock reviews
Pfaff coverlock 3.0 I can't get it to work properly for coverstitch. Brand new, already been back to store they serviced said nothing wrong. Got it home, removed their coverstitch test swatch and put my material under it, no go just jams all the time using this feature - have made a skirt using the overlock function all worked but can't hem it with this coverstitch. Re-treaded 20 times or more, watched the DVD over & over and see nothing wrong with how mine is treaded. It will do a few cms then just jam.....done than 10 times already just today. WHY?
    Genius:
  • 1,067 Answers
Go backmto dealer and do yiur own demo in front of them.You will get a better answer then.
Posted on May 02, 2017
SOURCE: thread bunching
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
Posted on Oct 17, 2007
  • 29 Answers
SOURCE: Brother SE-270D Jams below needle plate
Comment by margecam52, posted on Aug 12, 2008 It's the bobbin thread. Also, it does not have to be Brother brand. Any 60wt thread will work. I get mine at http://www.threadart.com
They have it on large cones, and I use a cone holder to fill my bobbins. I have not had a single problem since. I like this thread because it has a sheen to it. I also have a longarm quilting machine & I use this bobbin thread 95% of the time. Also, be sure to check the bobbin area (remove the plastic & the metal plates) for lint buildup... I have a small, soft artists paint brush that I use to remove the lint build up with. I check after every embroidery run.
And for the thread not coming through...mine does it when I change thickness of threads. There is an adjustment wheel on the front of the machine, I turn that...seems to make the difference...not even sure that is what it's for...but it works for me.
Posted on Aug 12, 2008
SOURCE: Kenmore 385. 11607 needle jams into shuttle or shuttle race
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Posted on Feb 05, 2009
  • 300 Answers
SOURCE: Sewing machine is jamming
The UPPER thread is not threaded through the machine correctly.
Posted on Feb 11, 2010
Testimonial: "That was part of the solution. I also adjusted the bobbin tension, together that solved the problem. thanks for your advice! "
SOURCE: singer 2250 bobbin jam
I had same problem. After making sure the thread was loaded properly still same thing happened. Then I reloaded the bobbin and made sure the long metal bar on the metal casing fit securely into the half circle slot at the top of the big metal ring that bobbin goes into. After that, just rotated handwheel a couple of times until thread came through. Problem solved.
Posted on Apr 16, 2010
I have a pfaff coverlock 4862 serger and the power which is triggered by the folding door in the front of it keeps shutting off. What sould I check?
There is a safety switch activated by the front door that apparently is not being fully de-activated. Perhaps the door is not straight or not completely closing.
Jun 04, 2017 | PfaFF Sewing Machines
I have a pfaff 907 machine that will not pick up the bobbin thread &It gets stuck. I have oiled &cleaned it & have followed the directions.
If you haven't already, try a brand new needle. If it is still a problem, most likely the machine is out of time. Search for sewing machine timing or take it for service.
Jan 25, 2017 | PfaFF Sewing Machines
936 Huskylock needle bar does not move up and down.
First, make sure the machine is engaged to sew. some machines,
have a knob inside the flywheel on the left side that disconnect the sewing mechanism to wind a bobbin without the needle bar moving.
Cheers,
Embroidery Services
San Diego, CA
Jun 15, 2016 | Sewing Machines
I have a pfaff 4.2 quilt expression brand new but cant make it work. The thread in the bobin keeps jamming? What cani do
thread jams or breakage generally points to incorrect thread tensions
read the hand book and adjust accordingly
Jun 10, 2015 | PfaFF Sewing Machines
Why does the left needle thread on my pfaff coverlock 4862 break
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Jul 15, 2014 | PfaFF Sewing Machines
What's a fair price for a used Ppfaff coverlock serger #4872 (Sept 2012)?
check on ebay & see what the pfaff coverlock is selling for
Sep 24, 2012 | Sewing Machines
The store lost my foot pedal and cord to my pfaff coverlock 4872 I need to know where i can buy another card.
You can try www.sewingmachineplus.com and they sell foot pedals. I saw a universal one too there. They have an 800 number too, so that you can call them before ordering. I hope the people who lost it on you are paying for it. Good luck
Nov 07, 2010 | Sewing Machines
What is the difference between Husqvarna 1003 lcd and 936. TY. Hug
The difference is that the 1003 is an older machine. The 936 is a newer machine and I have one. I bought mine new in 2003 so it's already a few years old and the 1003 is much older than that. The 936 has already been replaced and as I understand from the Viking store not made in Sweden any more. The real differences are the LCD screens, the location of the dials, the looks of the machines and of course the AGE of the machines and the price. It's always easier to get parts for a newer machine and the 936 should come with a DVD. They both do the same overlock stitches. The coverstitch is the main reason you would buy one of these machines. If you AREN'T going to do the cover stitch (the twin needle look) don't buy one of these because you will pay more money and have more mechanisms to work with. (If you don't need the coverstitch, look for a Huskylock 910. It's just like the 936 but without the coverstitch. You still get the beautiful display, the free arm and the lower looper threader.) If you look on eBay under huskylock 1003 and 936 there are two machines you can see. The 1003 is bid up to 305 dollars and has 20 hours more for bidding. The 936 has a buy it now price of 750 dollars or best offer. You could offer them 350 and see if they take it or go up to 500. I paid 1000 new in 2003. Both say 7 day money back guarantee. If you go to a Viking store and see the new one (I forgot what number replaced the 936) the cover stitch is easier to set up on this one. Good luck picking a new serger. You'll love it! Feel free to ask if you have any other questions. Thanks for using FixYa!
Sep 19, 2010 | Husqvarna Sewing Machines
Sewing Machines Logo
53 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
